Woohooo... Boost Machine is in.... 6.5 turns = pretty fun! Can I go more?
what's the concensus for a pretty aggressive setting?
I'm spiking 1.5-1.6 bar... holding about 1.4 and tapers off..... (don't exactly remember at what RPM or how much)
6.5 turns boost
3/4 turn creep
6.5 turns boost
3/4 turn creep
Your fine there.....>>
More boost=more heat and you'll fall out of the efficiency range. Some have found the car is stronger at 22PSI (1.5 bar) or lower because the resultant heat at higher boost levels pulls back timing....
Don't get too crazy...
Re: I've got a VAG... i'll see how high I can go.. haha
Take the save way and look at your egt's in group 217. Never ever go over 950°C. You'll see your lambda values too in that group.
ColoQuattro
16
03-21-2008 02:17 PM
drgolfnut
10
10-10-2006 12:57 PM
freeman
13
09-01-2001 03:29 PM
