XM roady install.
XM roady install.
i got a roady XM tuner yesterday. after trying
about 5 different places to mount the damn thing, i came up with the following, and it appears to be surprisingly clean.
here is where i have it mounted currently.
i took the insert out of the ash tray, which gives
more room for mounting.
<img src="http://pictureposter.audiworld.com/79271/picture046_07oct04.jpg">
and here is where i mounted the antenna. thankfully it's extremely small.
<img src="http://pictureposter.audiworld.com/79271/picture047_07oct04.jpg">
i'm thinking that tonight i'm going to try and remove the entire tray assembly, and see if the supplied mounting brackets will hold the device somewhere down there, so i can still access the compartment underneath.
Yep, I put mine in the same place, but I have a roadster so . . .
I've got the antennae on the dash, up against the windshield. Reception is OK. The biggest problem I have is with the FM. There are areas of town where I can't get a clear station. I'm pretty sure that I'm going to get the Bipes adapter so I don't have to worry about a clear FM station.
[Arawan]
12-14-2003 10:22 AM
docmusolf
03-10-2003 08:19 AM
