Yum......the latest mod edition is in>>>
#11
A well known 1.8t tuner>>>
Tony Chick over here in CT....i think you have heard of him...;-)
It will be a dyno run, then pulling the programming from the my Eprom socketed chip....then saving it.
Once that is done, Tony will modify the programming according to the dyno results and needs....
at this point, it will be the end of KO4 tuning for me....there is really nothing left at that level....and i am not going big turbo....should be interesting...
#16
Software questions>>>
I have "Waynes O2 Block" which as you probably know relocates the O2 sensor to off the pipe on a 90 degree angle...with the test pipe it dosn't work...
What software modifications are you thinking of doing? Also what software are you running?
#18
Running......>>>
GIAC's software.....the modifications will be done by a pro..first and foremost is to remove the CEL, then maybe some fine tuning from there...
It is not a flash program, so there in itself is an advantage....
#19
Hey Hans, why not go to an ATP? Cheap, its bolts right up and you have a guy to program it.
There is a company not far from me that did it on the 225TT and got about 300whp out of it. I'm thinking of giving them a go if my Turbo quits.
#20
Considered it....actually considered going bigger>>>
but based on the conversation with the tuner, he feels i will not get the driveability i want....until i can drive something tuned like that, i am gonna hold off.....
