Zerk fittings for sway bar
<center><img src="http://pictureposter.audiworld.com/40046/tt_zerk_005.jpg"></center><p>
Several weeks ago I helped a friend install the an ABD Racing hollow sway bar on his VW. I suggested that we might add a set of zerks to the bushings.
Using a 6mmx1 drill and tap set I drilled and tapped each bushings metal carrier for a 6mmx1 zerk. Futher, I continued the 6mm hole all the way through the bushing. Using a small round #192 dremel cutter I cut a (3/16")5mm round groove on the inside of the bushing to provide a greaseway.
This is going to be my next mod on my TT. I plan on using the small grease gun with Si grease that is available as Si marine grease.<ul><li><a href="http://www.widgetsupply.com/page/WS/CTGY/dremel-burr-cutter-hss-round">http://www.widgetsupply.com/page/WS/CTGY/dremel-burr-cutter-hss-round</a</li></ul>
zerg?
<center><img src="http://pictureposter.audiworld.com/63977/zerg.jpg"></center><p> couldnt help myself
is this mod applicable to the non hollow sway bars? sorry, I really dont understand what you did here, but I am interested, it gets tiresome dropping the bar everytime that squeaks begin.
Jet Jockey/A4 Pilot
05-17-2007 06:59 AM
Jet Jockey/A4 Pilot
05-17-2007 05:58 AM
Jet Jockey/A4 Pilot
Canadian Discussion
05-16-2007 08:54 AM
