Car wont start/no dashboard lights
Hi. Hope some one can help. I have a audi tt roadster 2008. I just replace the battery. The car will not turn over. When I put the key in the on position
the dash board doesn't light up either. Just the radio works. Also the window's will not go down. Any suggestion.
same issue - did you figure it out?
Hi i can't seem to find any responses to your post, did you figure it out, i have the exact same issue.
Audi tt mk2 clean battery terminals and fuses after that test the voltage! Then open ignition cover turn the ignition on and test the voltage if nothing then its ignition switch 👍
Hi I also had that and some weird things happen at ounce on my 2012 tt Quattro P. But with mine the dash had this issue too plus the top did not work at times among way more then I can even state in here. Its like my car is having a rolling outage or issues one after the other for no clear reason. I did get my dash working again by running the car completely dead then jump starting it. I need to speak to some ppl about all my issues but not sure how to go about it in here.
No dashboard
Muzza668
Q7 MK 1 Discussion
05-20-2013 10:03 AM
