Hard Wiring of Radar Detector
Many years ago, I used to hard wire the detector to the fuse box, ....hide the cable from front of window in the seam between window and top of dash....down behind dash to fuse box. But, that was before the fuse boxes were located inside the engine compartment with a fire wall between. The fuse boxes on my old cars were often located inside the passenger compartment.
Couple questions out there for anyone who has done this already on a TT (mine is an '08):
1. Is there an easy way to get into engine compartment with hard wire?
2. If so, where is the hole, and is there a specific fuse I should connect to?
3. If not....or if so.....is it easier to clip onto an existing wire under the dash for power?....and if so, which one?
thanks all....
Just take your time not that bad.
