TT (Mk2) Discussion Discussion forum for the Mk2 Audi TT, TT-S and TT-RS Coupe & Roadster produced from 2007-2014
how can I make my 2012 audi play my music from my Samsung S7 (using spotify)?
Old 01-12-2018, 08:37 AM
josemiguelvasc's Avatar
Default how can I make my 2012 audi play my music from my Samsung S7 (using spotify)?
I have a Audi A4 2012 with a MMI and sat nav.
Does anyone know how can I play the music from my samsung S7 in the MMI? I tried with the cable but it says that it does not support the device. Many thanks.
Old 01-13-2018, 03:29 AM
Vegas-roadster's Avatar
Default Try the A4 forum. This is the TT forum
Old 01-13-2018, 10:00 AM
Beartaez's Avatar
I am using the Bovee Bluetooth and works for on my 2012 tts with an S8. Is kind of expensive like $87 but that the only good on I could find. I am sure they probably others out there that might be cheaper. The only issue is that it does not display the play list or title of the song. I have not tried spotify yet though. Will update after I do.
Old 01-13-2018, 11:30 AM
Default Thanks
Thank you, that is really helpful!! Would you mind to have a look with the Spotify and see if works? If it does, I will get one for me again, massive thank you!
Old 01-13-2018, 12:52 PM
Beartaez's Avatar
It does work with spotify but again, no playlist, name of song, or name of artist.
Old 01-14-2018, 10:46 AM
Default Great!
Shame it does not show those details but so far this is the best and only option that I have heard so far.
If you are connected and playing your music, how does it work if you receive a phone call? can you still answer using the steering wheel keys?
Old 01-15-2018, 09:50 AM
Beartaez's Avatar
I have not gotten a call in the car yet so can' commet on that. I assume when you get a phone call, you can switch between the call and music.
Old 02-13-2018, 03:35 PM
RWBaconTT's Avatar
You can place a call via the AMI/MMI system over bluetooth. And stream music over the other Bluetooth unit. I do it in my 2014 TT. I use the carpro unit from CoolStream since it saves you about $10.
Old 02-13-2018, 07:55 PM
Beartaez's Avatar
https://www.youtube.com/watch?v=KsBfWgrMapQ
Thanks. The video was helpful. I was wandering why each time I push the phone bottom, it says that my phone is .au not be connected but I can play music.
Old 02-14-2018, 04:47 AM
RWBaconTT's Avatar
Just make sure the preferences are set properly for each BT device :-)
Quick Reply: how can I make my 2012 audi play my music from my Samsung S7 (using spotify)?
