New 2008 audi tt owner/ radio question
Hi evreyone,
I just bought 2008 audi tt coupe. It has symphony radio with cd player/Bose speakers and ipod connector in glovebox. I would like to use 3.5mm Jack to connect to my android phone or mp3 player. . I searched a lot and can't find rigid answer to this. I saw a female ipod to 3.5mm cable on ebay. Will it work? Somthing like this http://a.co/eEqQZkP
Use the AUX 3.5 mm jack input
Hi evreyone,
You looked here?
Another variant is shown here https://www.bing.com/images/search?v...put&ajaxhist=0
My '11 doesn't have the aux either. Audi does make a 3.5mm adapter for the connector in the glovebox for ~$80. Or you can order the 5' cable version through E-Bay for ~$11. I did the latter and it works just fine.
https://www.ebay.com/itm/AMI-MMI-MDI...YAAOSwVVRac7-t
Plug it in, keep it in the glovebox when not needed, and pull out and use when you want to. And, yes, the glovebox closes when the cable is out.
Does this ebay cable work? I head lot of people tried it and it doesnt work. Mine is 08 tt with symphony
It works for me. I figured for $11 it was worth trying. I'm not affiliated with the seller, but the link is the cable from the vendor I bought it from. As I noted, I have it plugged in, keep it in the glovebox when not needed, and pull out and use when I want to. And, yes, the glovebox closes when the cable is out. I use an mp3 player with it.
The cable I showed in the link does not connect to an iPod. One end connects to the MMI plug in the glovebox of the car and the other is a 3.5mm plug. You may want to look closer. My car's prior owner had the MMI to iPod cable. You may have a short MMI to iPod cable plugged in already. If so, you can unplug it (see your owner's manual) and then plug in the one I linked. If not, then you'll have to find another adapter.
