Wanting to add sub to 17TT Roadster with B&O
#51
Here you go .. didnt need to remove the driver's seat. Just put it up to its highest setting and it should give you enough clearance to remove the digital amp. Unplug the cable from it and you can see the wires where you can tap into. Refer to the wiring diagram above to tap into the correct ones, i used Posi-Tap. With the amp removed, it also allows you to run the speaker wire under the carpet through the rear seats and to the trunk for clean installation.
#53
CURSH[silverbullet]
10-18-2005 08:36 AM
EasTTcoasTT
13
12-24-2003 09:42 AM
