VAG-COM Discussion
Any documentation on correct values for common problems?
Old May 28, 2005 | 05:55 AM
javedikian's Avatar
Default Any documentation on correct values for common problems?
For example, to check if you have a healthy (MAF, or DV or, whatever) the following measuring blocks should be about X.
I check numbers once in a while and yeasterday in block 002 I had a max Air Mass Flow of 146 g/s @ 6000rpm. I thought it should be over 160 for a stock 225 TT. Block 032 Part Throttle Value max was 11.7 which I think is OK? And my Cmd Pressure in block 115 was a max of 2080 @ 4920 rpm.
Old May 29, 2005 | 01:15 PM
Theresias's Avatar
Default We are working to expand the existing label files also with specifications for each blocks...
...whats your engine code?
...or better whats your ecu part number?
Which VAG-COM version are you using? Version number?
Old May 29, 2005 | 03:22 PM
javedikian's Avatar
Default version
VAG-COM 409.1-s. Not sure where to get the ECU number but the engine code is AMU? I just noticed the labels so maybe the info I need is in there. However, I always get the values then go inside to look over them and since the car is not connected, I don't get the labels. So it would be helpful to have a document with the acceptable ranges.
ModestW12
10
Jul 21, 2018 12:16 PM
ajg617
Aug 31, 2013 09:51 AM
CUL8R
Aug 2, 2005 08:35 AM
Mx-3GSR
VAG-COM Discussion
Feb 2, 2005 05:15 PM
WAY
Apr 18, 2002 06:35 PM
