VAG-COM Discussion
Can I run the leak detection pump with version 311?
Old Aug 13, 2011 | 10:42 AM
turbo510's Avatar
Default Can I run the leak detection pump with version 311?
My '99 1.8T (Passat) throws an insufficient vacuum code (16825), and I'd like to test run the LDP if there is a way. In group 071 I can see the reed contact status change from open to closed when starting the engine, but the test aborts. Can I run this thing with the engine off? I don't see any output tests for that.
Old Aug 15, 2011 | 01:06 AM
Theresias's Avatar
VAG-COM 311/409 are no longer supported, a free update to VCDS-Lite is available to registered customers as well as non-customers. Obviously you will need a license/activation to run a basic setting.
http://www.ross-tech.com/vcds-lite/download/index.html
Old Aug 15, 2011 | 10:47 AM
turbo510's Avatar
I do have a licenced copy of -311, and can run basic settings. So can that version operate the LDP? Can VCDS-Lite do it? If -311 can't, and VCDS-Lite can, is the licence transferable? By the way, I may (hope) to have found a couple of loose clamps that could have caused leaks.
By the way, what was the basic difference between -311 and -409?
Old Aug 21, 2011 | 06:40 PM
Dana @ Ross-Tech's Avatar
Depending on the specific 1.8T this ECM may or may not support a LDP output test. The repair manual should include this information in this case. Since the fault is specific to insufficient vacuum it would be best to check the vacuum at the LDP rather that rely on Key On, Engine Off results.
See the page linked above:
Note to registered users upgrading from older versions:
* If you're upgrading from an older version such as VAG-COM version 311 or 409, you will need a new activation.
** First, install the VCDS-Lite and test it thoroughly in shareware mode as described above.
** Then go here and fill out the appropriate form - or buy a license if you don't have one yet.
If you purchased a SWL from us in the past, you will choose:
If you're using VCDS-Lite and already have a license (even for an old version of VAG-COM)
* Click here to request an activation for VCDS-Lite.
See the Revision History for Major Releases page.
Enclave
VAG-COM Discussion
Apr 20, 2007 12:08 PM
Cjshutts
VAG-COM Discussion
Sep 12, 2004 02:07 PM
Type44Q
May 7, 2003 06:18 AM
