VAG-COM Discussion
Output Tests: Error: Function Not Available
Old Apr 20, 2007 | 12:05 PM
Enclave's Avatar
Default Output Tests: Error: Function Not Available
I get this error when trying to run the output tests on the engine module. I was running those tests 5 mins before and when I tried to run them again I get that error. I tried to unplug, turn off etc.. computer and the car, still get that error.
Thanks.
Old Apr 20, 2007 | 12:08 PM
Andy@Ross-Tech's Avatar
Banned
Default You probably need to start and run the vehicle between sessions:
"Most Control Modules will permit the Output Test Sequence to be run only one time per session. If you run the Test Sequence to completion, VAG-COM will allow you to return to the previous screen without closing the session, but you may not be able to run the Output Test Sequence again. If you need to run the Sequence again, manually Close the Controller and re-start the session. On some cars, you must cycle the key OFF and ON or even start the engine (to clear the cylinders of fuel)."<ul><li><a href="http://www.ross-tech.com/vag-com/tour/out_test.html">http://www.ross-tech.com/vag-com/tour/out_test.html</a</li></ul>
turbo510
VAG-COM Discussion
Aug 21, 2011 06:40 PM
silversurf3r
Sep 3, 2005 12:47 PM
run_n_late
Sep 12, 2003 12:16 PM
