coding help please
Address 08: Auto HVAC
Part No: 8P0 820 043 H
Component: KlimavollautomatH17 0200
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
008 - Implausible Signal - Intermittent
Address 19: CAN Gateway
Part No: 1K0 907 530 F
Component: Gateway H10 0120
Coding: 3D0F0B42070100
Shop #: WSC 06314
3 Faults Found:
01304 - Radio
004 - No Signal/Communication - Intermittent
01044 - Control Module Incorrectly Coded
000 - -
00457 - Control Module for Network (J519)
Address 37: Navigation
Part No: 8P0 035 192 A
Component: RNS-E HIGH EU H70 0450
Coding: 0205717
Shop #: WSC 30899
5 Faults Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit
00878 - Connection to Speaker Front Left
011 - Open Circuit
00879 - Connection to Speaker Front Right
011 - Open Circuit
Address 77: Telephone
Part No: 8P0 862 335 M
Component: FSE_255x BT H21 0200
Coding: 0011444
Shop #: WSC 00000
1 Fault Found:
00466 - Control Module for Steering Column Electronics (J527)
I tried to activate multifunction steering wheel for A3 8P 2005....without lucky...because vag not permit me to recode it.
While I was trying to recode...I could see all this errors...
Is there anyone which could help me. Thanks
VAG-COM Version: Release 512.4-UD
Chassis Type: 8P - Audi A3
Scan: 01 02 03 08 09 0F 15 16 17 18 19 22 25 36 37 42 44 46 47 52
55 56 57 62 69 72 76 77 7D
VIN Number: WAUZZZ8P16A065040
Address 01: Engine
Part No: 03G 906 016 FF
Component: R4 2,0L EDC 0000SG 7364
Coding: 0000072
Shop #: WSC 06314
No fault code found.
Readiness: N/A
Address 03: ABS Brakes
Part No: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Coding: 0023170
Shop #: WSC 06314
1 Fault Found:
008 - Implausible Signal - Intermittent-------------------------------------------------------------------------------
Address 09: Cent. Elect.
Part No: 8P0 907 279 F
Component: Bordnetz-SG H36 1201
Coding: 41884F068214100000000000000000000008FE175C0100
Shop #: WSC 06314
Part No: 8P1 955 119 B
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Part No: 4E0 910 557
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 06314
Address 15: Airbags
Part No: 8P0 959 655 H
Component: Airbag 9.41 H11 3520
Coding: 0070612
Shop #: WSC 06314
Address 16: Steering wheel
Part No: 1K0 953 549 AF
Component: Lenks?ulenmodul 034 0070
Coding: 0000012
Shop #: WSC 06314
Address 17: Instruments
Part No: 8P0 920 930 R
Component: KOMBIINSTR. VDO H80 0410
Coding: 0004113
Shop #: WSC 08815
Shop #: WSC 06314
3 Faults Found:
01304 - Radio
000 - -
004 - No Signal/Communication - Intermittent-------------------------------------------------------------------------------
Address 25: Immobilizer
Coding: 0205717
Shop #: WSC 30899
5 Faults Found:
011 - Open Circuit
011 - Open Circuit
011 - Open Circuit
00857 - CD Changer Unit (R41)
Address 42: Door Elect, Driver
Part No: 8P0 959 801 F
Component: Tuersteuerger. H10 0040
Coding: 0000048
Shop #: WSC 06314
Address 44: Steering Assist
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
Address 46: Central Conv.
Part No: 8P0 959 433 B
Component: KSG H03 0040
Coding: 188000186D288505488A016300
Shop #: WSC 06314
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 47: Sound System
Part No: 8P3 035 382
Component: AB2 SUBWOOFERBOXH27 0160
Address 52: Door Elect, Pass.
Part No: 8P0 959 802 F
Coding: 0000048
Shop #: WSC 06314
Address 56: Radio
Coding: 0205717
Shop #: WSC 30899
5 Faults Found:
011 - Open Circuit
011 - Open Circuit
011 - Open Circuit
Coding: 0011444
Shop #: WSC 00000
1 Fault Found:
Address 7D: Aux. Heat
Part No: 1K0 963 235 E
Component: PTC-Element 0404
End --------------------------------------------------------------------------------------------------
I got in my car Board computer, not check system.
Thanks
