Engine -> Measuring Blocks -> Block 003 is labelled incorrectly
<center><img src="http://pictureposter.audiworld.com/32524/screen01.jpg"></center><p>
As you can see, the area that should be labelled "Thottle Angle" (third from the left; between "Mass Flow" and "Ign. Timing"), is incorrectly labelled "Load" on my VAG-COM screen. Why would this be? Is there a way to correct it?
I'm not sure if there are more incorrect labels or not, but this is the first one I have found.
BTW, I am running VAG-COM Release 504.1 with a KEY-USB cable on a 2000 S4 (B5).
Ah, it's not labelled at all...
It says: "Label File: None". That means VAG-COM is using a best-guess based on the data type. That type is used for various percentages, most often "load".
What's your ECU's VAG Number? Sounds like we may have goofed on the label files in this distro -- they got a LOT of revisions using the redirection scheme to eliminate duplication and increase coverage.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
Hi. Thanks for the reply. Not sure what you mean by my "ECU's VAG number"...
My ECU is an A-Box (i.e. 8D0...A), I'm not sure of all the numbers in the actual VAG part number, but I can check for you. Or, if you mean something else, just let me know and I'll be sure to post it for you ASAP.
I may be mistaken, but I think this data block was labelled in the previous revisions; I can vividly remember seeing it before in that exact measuring block. I just updated to Release 504.1 last week.
8D0 907 551 A ?
Strange, because I just put that ECU on the test bench and checked with a freshly installed 504.1. It loads 8D0-907-551.LBL and shows "Throttle angle" for Group 003, Field 3.
Please wipe your VAG-COM folder completely (or rename it if there's something in it you want to save), then re-install 504.1 and let me know if that doesn't fix it.
-Uwe-
-Uwe-
***Update*** Reinstallation did fix the problem. Thanks for your help...(m)
<center><img src="http://pictureposter.audiworld.com/32524/screen02.jpg"></center><p>...any ideas what could have caused this? Should I be worried about other measuring blocks being mis-, or incorrectly labelled, or would this problem have been localized?
vlad2.7T
08-23-2006 12:54 PM
Asicks2.7T
12-22-2005 04:17 AM
BigJonUK
01-12-2005 08:39 AM
A4X4
04-30-2003 05:49 PM
