VAG-COM Discussion
Sponsored by:
Sponsored by:
Is there a way to disable the Auto Lock of the car.. Not the speed based one..
Old 06-29-2008, 07:47 AM
Maini's Avatar
Default Is there a way to disable the Auto Lock of the car.. Not the speed based one..
But the one which locks the car if you do not open a door for couple of minutes... it is annoying and I managed to lock my keys inside once too..
I put my keys inside on the seat and closed the door to get something and the car locked itself...
Old 06-30-2008, 10:56 AM
Audiworld Premium Sponsor
Uwe@Ross-Tech.com's Avatar
Default No, but.. Something is wrong there.
I believe that the only time it should lock itself is if you use the remote to unlock it and do not open any doors for whatever the timeout is (30 or 60 seconds, I've forgotten). If you open a door while it is unlocked, it should not lock itself. Hence it should not be possible to put your keys in the car and lock them in there.
-Uwe-
http://www.Ross-Tech.com
Old 06-30-2008, 11:36 AM
Maini's Avatar
this did happen.I have recently coded to 15581 from 15585 for single button unlock of all doors..
Old 07-01-2008, 02:14 PM
Theresias's Avatar
You may want to double check the door contact switches by using the measuring blocks.
Old 07-13-2008, 12:29 PM
Maini's Avatar
Default Yup checked the contact the driver one was bad.. so I mod it and now everything is working fine
<ul><li><a href="https://forums.audiworld.com/a6/msgs/799111.phtml">https://forums.audiworld.com/a6/msgs/799111.phtml</a</li></ul>
sashko
Q7 MKII Discussion
13
07-26-2023 11:14 PM
smarty666
Q5/SQ5 MKI (8R) Discussion
11-02-2015 04:54 AM
Crisis3
06-28-2014 05:07 AM
alms_lefko
11-01-2005 01:01 PM
CooliceTTT
01-26-2002 01:33 PM
Quick Reply: Is there a way to disable the Auto Lock of the car.. Not the speed based one..
