VAG-COM Discussion
Sponsored by:
Sponsored by:
First SCAN! Audi A6 4.2v8 2001 Tip
Old 04-12-2007, 03:36 PM
acapella8's Avatar
Default First SCAN! Audi A6 4.2v8 2001 Tip
Hi all,
My KEY-USB arrived today, and although I could not get it to install on one laptop (invalid data when trying to install USB) I got it to work on my wife's laptop.
anyway --- hope it's not too long, but this is my FIRST scan!
Questions before I paste:
1. best way to clear "intermittent" DTCs?
2. Does anyone see anything to be concerned about?
Thanks -- here's my FIRST scan! (Tom)
Thursday,12,April,2007,18:22:38:32056
VAG-COM Version: Release 704.0
Data version: 20070404
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
VIN: WAUZL54B11N159232
Address 01: Engine Labels: None
Part No: 4D0 907 560 AE
Component: 4.2l V8/5V G 0003
Coding: 07752
Shop #: WSC 02325
WAUZL54B11N159232 AUZ7Z0A1859414
3 Faults Found:
18032 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 35-10 - - - Intermittent
16825 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 35-00 - -
17521 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: None
Part No: 4B0 927 156 CT
Component: AG5 01L 4.2l5V USA 0708
Coding: 00002
Shop #: WSC 02325
1 Fault Found:
18228 - Pressure Control Valve 2 (N216): Short to Plus
P1820 - 35-10 - - - Intermittent
Address 06: Seat Mem. Pass Labels: None
Part No: 4B0 959 760 C
Component: Sitzmemory R1 BF 0102
Coding: 00003
Shop #: WSC 00000
No fault code found.
Address 08: Auto HVAC Labels: 4B0-820-043-MY1.LBL
Part No: 4B0 820 043 AH
Component: A6-Klimavollautomat D65
Coding: 00180
Shop #: WSC 65289
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 15: Airbags Labels: 4B0-959-655-AI8.LBL
Part No: 4B0 959 655 F
Component: Airbag Front+Kopf 2002
Coding: 00405
Shop #: WSC 02325
Address 16: Steering wheel Labels:
Address 17: Instruments Labels: 4B0-920-xxx-17.LBL
Part No: 4B0 920 981 G
Component: C5-KOMBIINSTR. VDO D12
Coding: 03283
Shop #: WSC 03311
Address 35: Centr. Locks Labels: 4B0-962-258.LBL
Part No: 4B0 962 258 J
Component: Central Lock/Alarm D34
Coding: 15885
Shop #: WSC 02325
3 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00956 - Key 2
09-10 - Adaptation Limit Surpassed - Intermittent
01559 - Drivers Door
58-10 - Can't Lock - Intermittent
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0101
Coding: 00001
Shop #: WSC 00000
Address 45: Inter. Monitor Labels: None
Part No: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00101
Shop #: WSC 02325
2 Faults Found:
01349 - Alarm via Theft Warning System; Front
35-00 - -
01350 - Alarm via Theft Warning System; Rear
35-00 - -
Address 55: Xenon Range Labels: 4B0-907-357-DYN.LBL
Part No: 4B0 907 357 C
Component: dynamiscoehe dynamische L
Address 56: Radio Labels: None
Part No: 4B0 035 195 A
1 Fault Found:
00850 - Control Output Active; Radio Amplifier
29-10 - Short to Ground - Intermittent
End --------------------------------------------------------------------------------------------------
Old 04-12-2007, 05:07 PM
Audiworld Premium Sponsor
Uwe@Ross-Tech.com's Avatar
Default One, Two
Go to the module that has the fault(s) and clear them, for example:
Select -> 01-Engine -> Fault Codes -> Clear Codes
Yep, the codes in the engine and trans should be dealt with. I'd clear 'em first and see how long it takes 'em to come back, but if/when they do, whatever is causing them needs to be fixed.
The codes in the locking system and interior monitor are just "advisory" and nothing to worry about.
-Uwe-
http://www.Ross-Tech.com
Old 04-12-2007, 05:30 PM
acapella8's Avatar
Thanks Uwe -- I got them cleared, will drive in AM and see if they return
Old 04-13-2007, 04:21 PM
acapella8's Avatar
Interesting, driven all day -- they did not return. I will monitor. Thanks.
David Cormier
New Member Welcome Area
01-18-2018 05:30 PM
captain_video
11-16-2016 09:34 AM
cutchemist42
06-07-2013 04:19 AM
Tonytza
VAG-COM Discussion
04-14-2008 07:14 AM
4.2LV8AUDI
VAG-COM Discussion
08-06-2007 01:38 PM
Quick Reply: First SCAN! Audi A6 4.2v8 2001 Tip
