VAG-COM Discussion
Help with some codes...
Old Jun 4, 2008 | 02:52 AM
CactusGreen's Avatar
Default Help with some codes...
2002 A6 3.0 oil burner, thrown up the CEL, and runs poor on start, gives me these codes.
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F0 910 401 L HW: 4F0 907 401 A
Component: 3.0L V6TDI G000AG 0040
Revision: --H01--- Serial number:
Coding: 0011772
Shop #: WSC 02335 785 00200
5 Faults Found:
17953 - Throttle Valve Controller: Malfunction
P1545 - 002 - Lower Limit Exceeded
Freeze Frame:
RPM: 0 /min
Torque: 167.7 Nm
Speed: 0.0 km/h
Voltage: 11.86 V
Duty Cycle: 92.7 %
Bin. Bits: 010
Mass Air / Rev.: 0.0 mg/str
Voltage: 0.000 V
17055 - Cylinder 1 Glow Plug Circuit (Q10): Electrical Fault
P0671 - 001 - Upper Limit Exceeded
Freeze Frame:
RPM: 903 /min
Torque: 152.1 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.83 V
Duty Cycle: 22.9 %
Temperature: 9.0°C
Bin. Bits: 10110000
17056 - Cylinder 2 Glow Plug Circuit (Q11): Electrical Fault
P0672 - 001 - Upper Limit Exceeded
Freeze Frame:
RPM: 903 /min
Torque: 152.1 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.83 V
Duty Cycle: 22.9 %
Temperature: 9.0°C
Bin. Bits: 10110000
17057 - Cylinder 3 Glow Plug Circuit (Q12): Electrical Fault
P0673 - 001 - Upper Limit Exceeded
Freeze Frame:
RPM: 903 /min
Torque: 152.1 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.83 V
Duty Cycle: 22.9 %
Temperature: 9.0°C
Bin. Bits: 10110000
17059 - Cylinder 5 Glow Plug Circuit (Q14): Electrical Fault
P0675 - 001 - Upper Limit Exceeded
Freeze Frame:
RPM: 903 /min
Torque: 152.1 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.83 V
Duty Cycle: 22.9 %
Temperature: 9.0°C
Bin. Bits: 10110000
Old Jun 5, 2008 | 03:59 PM
tepps's Avatar
Default Re: Help with some codes...
sounds like you need somew new glow plugs. that is why it runs poorly on start up
Old Jun 10, 2008 | 02:54 AM
AFAIK plugs were changed last service - about 12K back....
A8Pete
Jul 17, 2018 07:30 AM
bahafeld
Audi 100 / A6 (C4 Platform)
Jun 2, 2013 02:47 PM
bahafeld
VAG-COM Discussion
Jun 2, 2013 02:50 AM
JBOB123
A4 (B7 Platform) Discussion
Jan 27, 2013 08:20 AM
Hola amigo va repost
2.0T FSI Discussion
Aug 3, 2007 05:15 PM
