Interior & Exterior Light Fault
Hi
New to here and a complete novice with car electrics.
I have a 2018 A3 S-Line saloon RHS drive (UK).
About a month ago i received a stack of error messages on the dash, initially all my interior lights failed - no footwell, boot, vanity mirrors etc and the dash dimmed upon starting the car; then some exterior lights stopped working - front indicator lights and side lights. Dash errors now say that “vehicle lights malfunction”, “front right turn signal”, “front left turn signal”, “front right side light”, “front left side light”, and “audi adaptive light fault”.
Checked fuses and all seem fine so it’s nothing obvious.
Plugged into a friends VAGCOM and the error sections are on Auto HVAC, Central Electrics and Instruments. I’ve pasted these below….
Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
Part No SW: 8V0 820 043 AE HW: 8V0 820 043 AE
Component: AC Automat H03 0150
Revision: 20003000 Serial number: 00000001539192
Coding: 03100104002000011000000000001100
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_AirCondiFrontVaAU37X 008025
ROD: EV_AirCondiFrontVaAU37X_008.rod
VCID: 75EBD997D4D98B27EC-8020
Humidity sensor: exterior:
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H02 0007
Serial number: 1E60D22900PAG0MUFU03
1 Fault Found:
459015 - Databus
U1121 00 [009] - Missing Message
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 39
Mileage: 45907 km
Date: 2022.07.07
Time: 20:12:51
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 DJ HW: 5Q0 937 084 CG
Component: BCM MQBAB M++ H36 0253
Serial number: 00001810400032
Coding: 00000000000000000000000000000000000000000000000000 0000000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_BCMMQB 018001
ROD: EV_BCMBOSCH_018.rod
VCID: 030FB74F8A0DA597D2-8056
Wiper motor control module:
Subsystem 1 - Part No SW: 8V2 955 119 C HW: 8V2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 180315 043 0585
Serial number: 180323134021
Coding: 0A47F7
Anti-theft alarm system sensor:
Subsystem 2 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY1807412WL
Alarm horn:
Subsystem 3 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0314
Serial number: 00000000000010276868
7 Faults Found:
9738 - Bulb for Left Parking Lamp
B12E8 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Mileage: 45907 km
Date: 2022.07.07
Time: 20:12:46
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): OFF
Status Bremslichtschalter (CAN): OFF
OFF: Not operated
Position lamps: Not operated
Automatic high beam assist: Not operated
Low beam: Not operated
Parking light left: Not operated
Parking light right: Not operated
last_wakeup: no cause for fault protection
Voltage: 11.9 V
Outside temperature: 22.0 °C
9994 - Bulb for Right Parking Lamp
B12E9 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Mileage: 45907 km
Date: 2022.07.07
Time: 20:12:46
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 11.9 V
525838 - Limp Mode
C10CA 00 [009] - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 39
Mileage: 45907 km
Date: 2022.07.07
Time: 20:12:46
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 11.9 V
527374 - Light Router
B1882 05 [009] - System Programming Failure
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 39
Mileage: 45907 km
Date: 2022.07.07
Time: 20:12:46
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 11.9 V
555797 - Databus
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 39
Mileage: 45907 km
Date: 2022.07.07
Time: 20:12:49
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 11.9 V
919560 - Light Switch
B126A 29 [009] - Signal Implausible
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 39
Mileage: 45907 km
Date: 2022.07.07
Time: 20:12:46
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 11.9 V
15361024 - Component Protection
U1101 00 [009] - Active
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 39
Mileage: 45907 km
Date: 2022.07.07
Time: 20:12:46
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 11.9 V
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 8V0 920 973 H HW: 8V0 920 973 H
Component: KOMBI H01 0311
Coding: 27A419002B8006000100E8001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009060
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 448D7453CF8362AFAB-8010
1 Fault Found:
1048578 - No Basic Setting
B2010 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Mileage: 45907 km
Date: 2022.07.07
Time: 20:12:46
Does anyone have any suggestions please?!
Thanks in advance!
1 Fault Found:
459015 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 39
Mileage: 45907 km
Date: 2022.07.07
Time: 20:12:51
Coding: 0A47F7
Alarm horn:
7 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Mileage: 45907 km
Date: 2022.07.07
Time: 20:12:46
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 11.9 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Mileage: 45907 km
Date: 2022.07.07
Time: 20:12:46
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 11.9 V
525838 - Limp Mode
C10CA 00 [009] - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 39
Mileage: 45907 km
Date: 2022.07.07
Time: 20:12:46
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 11.9 V
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 39
Mileage: 45907 km
Date: 2022.07.07
Time: 20:12:46
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 11.9 V
555797 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 39
Mileage: 45907 km
Date: 2022.07.07
Time: 20:12:49
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 11.9 V
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 39
Mileage: 45907 km
Date: 2022.07.07
Time: 20:12:46
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 11.9 V
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 39
Mileage: 45907 km
Date: 2022.07.07
Time: 20:12:46
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 11.9 V
1 Fault Found:
B2010 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Mileage: 45907 km
Date: 2022.07.07
Time: 20:12:46
Thanks in advance!
jmayfield23
16
02-24-2019 07:34 PM
Avi Ryeson
03-20-2015 12:28 PM
blueyucca
02-23-2011 09:08 AM
