Interior Motion Sensor Module Error
Controller uses unknown Protocol!
Protocol Keyword:FF01
I also did an auto-scan, and there are no DTC's, but it can scan module 45 using a different protocol. Why doesn't this work when I try to connect directly to this address? Is there a workaround? I am able to connect to and modify all other addesses.
Result of scan:
VAG-COM Version: Release 409.0-US
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56,76
Address 01: Engine
Controller: 4B0 907 551 T
Component: 2.7l V6/5VT G 0001
Coding: 06752
Shop #: WSC 02325
WAUED64B31N122247 AUZ7Z0Y1764840
No fault code found.
Address 02: Auto Trans
Controller: 4B0 927 156 DJ
Component: AG5 01V 2.7l5VT USA 1717
Coding: 00032
Shop #: WSC 00000
Address 03: ABS Brakes
Controller: 8D0 907 389 E
Component: ABS/ESP allrad D56
Coding: 06397
Shop #: WSC 08252
Address 08: Auto HVAC
Controller: 4B0 820 043 AH
Component: A6-Klimavollautomat D65
Coding: 00160
Shop #: WSC 02325
Skipping Address 15-Airbags
Address 16: Steering wheel
Controller: 4B0 907 487 D
Component: Lenkradelektronik D03
Coding: 00102
Shop #: WSC 65535
Address 17: Instruments
Controller: 4B0 920 981 G
Component: C5-KOMBIINSTR. VDO D12
Coding: 02264
Shop #: WSC 08815
Address 35: Centr. Locks
Controller: 4B0 962 258 J
Component: Central Lock/Alarm D34
Coding: 15981
Shop #: WSC 02325
Address 36: Seat Mem. Drvr
Controller: 4B0 959 760 B
Component: Sitzmemory R1 F 0101
Coding: 00001
Shop #: WSC 00000
Address 45: Inter. Monitor
Controller: OBD-II/EOBD, Protocol Keyword: $01FF
Address 55: Xenon Range
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00006
Shop #: WSC 02325
Address 56: Radio
Controller: 4B0 035 195 A
Component: Radio D00
Coding: 01152
Shop #: WSC 00000
End --------------------------------------------------------------------------------------------------
If that doesn't solve the problem, I'd be thinking in terms of and issue is with your interior monitoring module. Check the connections to it, maybe some corrosion or a bad ground would be my guess, or possibly a flaky module.
-Uwe-
