VAG-COM Discussion
issue with recoding abs module
Old Jul 13, 2010 | 09:20 AM
audifirst's Avatar
Default issue with recoding abs module
my 1999 a6, had problem with bad abs module , I got another module, fixed it, however I have issue with recoding, original code is 00031 car with CAN bus communication, and my car is non-can, so I am trying to recode back to original module coding which was 00003 and it won't let me, so I am assuming i need to log in first but I don't have login code is there a generic code for abs module ?
Old Jul 13, 2010 | 10:31 AM
Theresias's Avatar
Post a complete scan from the vehicle in question please.
Old Jul 13, 2010 | 10:42 AM
audifirst's Avatar
VCDS Version: Release 10.6.0
Data version: 20100630
Tuesday,13,July,2010,14:40:30:39530
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
Mileage: 242510km/150688miles
Address 01: Engine Labels: 078-907-551-AHA.lbl
Part No: 4D0 907 551 AH
Component: 2.8L V6/5V MOTR AT D03
Coding: 06252
Shop #: WSC 40802
VCID: 6CDC219E36E3
No fault code found.
Readiness: 0110 1101
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4B0 927 156 G
Component: AG5 01V 2.8l5V USA 8509
Coding: 00000
Shop #: WSC 00000
VCID: 2B5EE282F36D
1 Fault Found:
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Address 03: ABS Brakes Labels: 8E0-614-111-ASR.lbl
Part No: 8E0 614 111 AH
Component: ABS/ASR 5.3 FRONT D10
Coding: 00031
Shop #: WSC 00028
VCID: 64CC49BEDE33
3 Faults Found:
00285 - ABS Wheel Speed Sensor; Front Right (G45)
30-00 - Open or Short to Plus
18258 - Powertrain Data Bus: Missing Message from ECU
P1850 - 35-00 - -
18034 - Powertrain Data Bus: Missing Message from TCU
P1626 - 35-00 - -
Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl
Part No: 4B0 820 043 Q
Component: A6-Klimavollautomat D62
Coding: 00160
Shop #: WSC 02325
VCID: 28541D8EE29B
Address 15: Airbags Labels: 4B0-959-655-AI8.lbl
Part No: 4B0 959 655 H
Component: Airbag Front+Seite 0002
Coding: 00106
Shop #: WSC 02324
VCID: 356AC4FA2529
Address 17: Instruments Labels: 4B0-919-xxx-17.lbl
Part No: 4B0 919 930 J
Component: C5-KOMBIINSTR. VDO D10
Coding: 06362
Shop #: WSC 00000
VCID: 2F66F692C775
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 J
Component: Central Lock/Alarm D32
Coding: 15885
Shop #: WSC 02325
VCID: 3064F5EEDA4B
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 A
Component: Sitzmemory D05
VCID: 2B5EE282F36D
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00002
Shop #: WSC 02325
VCID: E0C4C5AE4A2B
End ---------------------------------------------------------------------
Old Jul 13, 2010 | 05:04 PM
Uwe@Ross-Tech.com's Avatar
Banned
There's no login needed to recode that module, so there's something else not right here. It's possible it won't let you due to the wheel speed sensor fault. Also, be sure the engine is not running when you try to recode it.
-Uwe-
kgardnez
Sep 15, 2020 01:26 PM
400runner
May 16, 2018 05:08 PM
iwokeupwithgills
VAG-COM Discussion
Sep 22, 2011 09:20 AM
dcsat
VAG-COM Discussion
Apr 21, 2010 08:02 PM
SpfldS4
Nov 2, 2004 04:56 PM
