OBDEleven VagCom Alternative
I recently purchased the OBDEleven and must say I am impressed. Many people (including myself) are sceptical due to the "Credits" system that are used with the device IF you do not know how to use the long coding. In a nut shell you only need the credits if you arent comfortable performing the tasks long code.....and by long code I simply mean using the same format as VagCom....module/adaptation/byte/bit. With this device I was able to disable wink, adjust LED intensity w/ headlights on, enable foglights w/ brights on, enable convenience windows/ sunroof, enable hidden menu on MMI, enable emergency brake lights (basically causes the brake lights to strobe if brakes are applied in an emergency), reset service interval, reset oil change interval, fault check, live data record/view, enable interior light intensity.....it does ALLOT.....and I havent used any credits to perorm these tasks.....total cost....$60.http://deutscheautoparts.com/vw-audi...obdeleven.html
