VAG-COM Discussion
oxygen sensor correction limit reached error code.....
Old Jan 26, 2004 | 02:30 PM
Vijay's Avatar
Super Moderator
25 Year Member
Default oxygen sensor correction limit reached error code.....
what does this mean?
Old Jan 27, 2004 | 03:30 AM
ChrisV's Avatar
New Member
Default Re: oxygen sensor correction limit reached error code.....
If it is negative by more than -10% your mixture is too rich: leaking injectors, fuel pressure too high, Leaking EVAP cannister purge valve, MAF reading too high
If it is positive by more than +10% your mixture is too lean: clogged injectors, fuel pressure too low, leak in inlet manifold vacuum system, MAF reading too low
Sten M
May 19, 2018 11:46 AM
Sten M
1.8T Discussion
Nov 9, 2017 09:19 AM
BlkNotes
Sep 8, 2013 07:18 AM
PearlA4_1
12v V6 Discussion
Jan 24, 2004 04:42 PM
RichMN
Apr 27, 2003 11:41 AM
