Need help, fuel consumption very high. (Fault codes included)
Hi!
My car details:
Audi A6 C5 1.8T 2000, Motor code: ANB
My fuel consumption has gone as high as 14l/100km. I cant be sure but I think it started after I changed MAF sensor, I dont know if this is associated with the high fuel consumption.
Fault codes:
VAG-COM Version: Release 409.1-S
Control Module Part Number: 4B0 906 018 AL
Component and/or Version: 1.8L R4/5VT G01 0002
Software Coding: 05002
Work Shop Code: WSC 02325
4 Faults Found:
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 35-00 - -
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-00 - -
17521 - Oxygen (Lambda) Sensor: B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
P0140 - 35-10 - - - Intermittent
Should I change both oxygen sensors or these fault codes can be due to a malfunctioning MAF sensor or MAF sensor is not associated with this.
I also understand that the first code means that I have to replace the engine coolant temp sensor. I have Googled the second code as well, but the information is a bit confusing.
I am really looking forward for your help.
My car details:
Fault codes:
4 Faults Found:
P0118 - 35-00 - -
P1557 - 35-00 - -
Some MAF readings with VCDS:Friday,27,October,2017,18:17:174B0 906 018 AL,,1.8L R4/5VT G01 0002,,Group A:,'003,,,,Group B:, Not Running,,,,Group C:, Not Running,,Idle speed,Air Mass In,Throttle Angle,Ignition Angle,,,,,,,,,,,TIME,740-920 rpm,2.0-4.5 g/s,0.2-4.0%,0-12°BTDC,TIME,,,,,TIME,,,,Marker,STAMP, /min, g/s,%, °BTDC,STAMP,,,,,STAMP,,,,,0.24,1720,20.06,10.6,18. 0,,,,,,,,,,,0.54,1720,28.44,13.7,13.5,,,,,,,,,,,0. 83,1720,29.47,15.7,10.5,,,,,,,,,,,1.14,1720,36.08, 59.6,4.5,,,,,,,,,,,1.43,1720,39.81,92.2,2.3,,,,,,, ,,,,1.74,1760,43.44,65.9,1.5,,,,,,,,,,,2.03,1760,4 5.89,83.1,0.8,,,,,,,,,,,2.33,1800,47.19,81.2,0.8,, ,,,,,,,,,2.64,1800,46.47,83.1,0.8,,,,,,,,,,,2.94,1 840,47.08,84.7,0.8,,,,,,,,,,,3.24,1840,45.67,84.3, 0.8,,,,,,,,,,,3.53,1840,47.11,82.4,0.8,,,,,,,,,,,3 .83,1880,9.72,3.1,4.5,,,,,,,,,,,4.13,1760,1.06,3.1 ,25.5,,,,,,,,,,,4.43,2200,20.39,2.4,16.5,,,,,,,,,, ,4.73,2200,2.72,2.0,1.5,,,,,,,,,,,5.03,2240,4.08,2 .4,15.8,,,,,,,,,,,5.34,2240,4.39,2.4,0.0,,,,,,,,,, ,5.63,2200,11.19,7.8,21.8,,,,,,,,,,,5.94,2200,40.9 2,30.2,3.0,,,,,,,,,,,6.23,2240,45.39,30.6,11.3,,,, ,,,,,,,6.53,2240,59.53,36.9,6.0,,,,,,,,,,,6.83,228 0,66.11,43.1,3.8,,,,,,,,,,,7.13,2320,69.58,87.8,5. 3,,,,,,,,,,,7.43,2360,69.00,100.0,5.3,,,,,,,,,,,7. 74,2400,66.61,100.0,6.0,,,,,,,,,,,8.03,2440,70.00, 100.0,6.0,,,,,,,,,,,8.33,2480,63.86,100.0,6.8,,,,, ,,,,,,8.63,2520,64.06,100.0,6.8,,,,,,,,,,,8.93,252 0,65.17,100.0,7.5,,,,,,,,,,,9.23,2560,66.50,100.0, 7.5,,,,,,,,,,,9.53,2600,68.53,100.0,7.5,,,,,,,,,,, 9.83,2640,67.47,100.0,7.5,,,,,,,,,,,10.13,2640,68. 89,98.4,7.5,,,,,,,,,,,10.43,2680,70.22,99.2,7.5,,, ,,,,,,,,10.73,2720,71.47,93.7,8.3,,,,,,,,,,,11.03, 2760,70.56,94.1,8.3,,,,,,,,,,,11.33,2760,71.92,94. 1,8.3,,,,,,,,,,,11.63,2800,73.39,89.4,8.3,,,,,,,,, ,,11.93,2840,75.39,89.4,8.3,,,,,,,,,,,12.23,2880,7 3.58,85.1,9.0,,,,,,,,,,,12.53,2920,75.58,85.1,9.0, ,,,,,,,,,,12.83,2960,77.28,85.5,9.0,,,,,,,,,,,13.1 3,2960,79.94,80.8,9.0,,,,,,,,,,,13.43,3000,76.78,8 0.8,9.8,,,,,,,,,,,13.73,3040,79.81,76.1,9.8,,,,,,, ,,,,14.03,3080,80.72,76.1,9.8,,,,,,,,,,,14.33,3120 ,81.69,76.5,9.8,,,,,,,,,,,14.63,3120,83.50,76.5,9. 8,,,,,,,,,,,14.93,3160,83.83,76.5,9.8,,,,,,,,,,,15 .22,3200,85.67,71.0,10.5,,,,,,,,,,,15.53,3240,85.1 4,71.4,10.5,,,,,,,,,,,15.83,3280,85.31,71.4,10.5,, ,,,,,,,,,16.13,3280,85.47,71.4,10.5,,,,,,,,,,,16.4 3,3320,86.00,72.2,10.5,,,,,,,,,,,16.73,3360,87.86, 62.4,11.3,,,,,,,,,,,17.03,3400,86.44,62.7,11.3,,,, ,,,,,,,17.32,3440,88.33,62.7,11.3,,,,,,,,,,,17.63, 3440,89.03,62.4,11.3,,,,,,,,,,,17.92,3480,89.14,61 .6,11.3,,,,,,,,,,,18.22,3480,89.14,60.4,11.3,,,,,, ,,,,,18.53,3480,12.97,7.5,14.3,,,,,,,,,,,18.82,320 0,5.58,3.5,7.5,,,,,,,,,,,19.12,2720,5.56,3.1,23.3, ,,,,,,,,,,19.43,2880,42.17,18.8,3.8,,,,,,,,,,,19.7 3,2800,70.67,36.5,4.5,,,,,,,,,,,20.02,2840,80.94,3 8.8,7.5,,,,,,,,,,,20.32,2840,72.58,25.1,7.5,,,,,,, ,,,,20.62,2840,26.33,10.6,12.0,,,,,,,,,,,20.92,284 0,12.42,6.7,21.8,,,,,,,,,,,21.22,2800,7.97,4.3,38. 3,,,,,,,,,,,21.52,2800,5.53,3.1,11.3,,,,,,,,,,,21. 82,2800,6.11,3.5,1.5,,,,,,,,,,,22.12,2760,6.36,3.5 ,1.5,,,,,,,,,,,22.42,2760,6.50,3.5,1.5,,,,,,,,,,,2 2.72,2720,6.19,3.5,1.5,,,,,,,,,,,23.02,2720,6.69,3 .1,1.5,,,,,,,,,,,23.32,2680,6.44,3.1,1.5,,,,,,,,,, ,23.62,2680,6.50,3.1,1.5,,,,,,,,,,,23.92,2680,6.36 ,3.1,1.5,,,,,,,,,,,24.22,2640,6.58,3.1,1.5,,,,,,,, ,,,24.52,2640,6.53,3.1,1.5,,,,,,,,,,,24.82,2600,6. 33,3.1,1.5,,,,,,,,,,,25.12,2600,6.53,3.1,1.5,,,,,, ,,,,,25.42,2560,6.22,3.1,1.5,,,,,,,,,,,25.72,2560, 6.19,3.1,1.5,,,,,,,,,,,26.02,2520,6.00,3.1,1.5,,,, ,,,,,,,26.32,2520,6.17,3.1,1.5,,,,,,,,,,,26.62,252 0,6.19,3.1,1.5,,,,,,,,,,,26.92,2480,6.14,2.7,0.8,, ,,,,,,,,,27.22,2480,6.36,2.7,0.8,,,,,,,,,,,27.52,2 440,6.17,2.7,0.8,,,,,,,,,,,27.82,2440,6.11,2.7,0.8 ,,,,,,,,,,,28.12,2400,5.94,2.7,0.8,,,,,,,,,,,28.42 ,2400,5.92,2.7,0.8,,,,,,,,,,,28.72,2360,6.03,2.7,0 .8,,,,,,,,,,,29.02,2360,6.08,2.7,0.8,,,,,,,,,,,29. 32,2320,5.75,2.7,0.8,,,,,,,,,,,29.62,2320,5.86,2.7 ,0.8,,,,,,,,,,,29.92,2320,5.53,2.7,0.8,,,,,,,,,,,3 0.22,2280,5.81,2.7,0.8,,,,,,,,,,,30.52,2280,5.97,2 .7,0.8,,,,,,,,,,,30.82,2280,5.56,2.7,0.8,,,,,,,,,, ,31.12,2240,5.64,2.7,0.0,,,,,,,,,,,31.42,2240,5.64 ,2.7,0.0,,,,,,,,,,,31.72,2200,5.50,2.7,0.0,,,,,,,, ,,,32.02,2200,5.69,2.7,0.0,,,,,,,,,,,32.31,2200,5. 64,2.4,0.0,,,,,,,,,,,32.62,2160,5.47,2.7,0.0,,,,,, ,,,,,32.92,2160,5.61,2.4,0.0,,,,,,,,,,,33.22,2120, 5.39,2.4,0.0,,,,,,,,,,,33.51,2120,5.33,2.4,0.0,,,, ,,,,,,,33.81,2120,5.53,2.4,0.0,,,,,,,,,,,34.12,208 0,5.44,2.4,0.0,,,,,,,,,,,34.42,2080,5.28,2.4,0.0,, ,,,,,,,,,34.71,2040,5.06,2.4,0.0,,,,,,,,,,,35.02,2 040,5.28,2.4,0.0,,,,,,,,,,,35.32,2040,5.06,2.4,0.0 ,,,,,,,,,,,35.62,2000,5.31,2.4,0.0,,,,,,,,,,,35.91 ,2000,5.03,2.4,0.0,,,,,,,,,,,36.22,1960,5.31,2.4,0 .0,,,,,,,,,,,36.51,1960,5.03,2.0,0.8,,,,,,,,,,,36. 82,1960,4.58,2.0,0.8,,,,,,,,,,,37.12,1960,4.67,2.0 ,0.8,,,,,,,,,,,37.41,1920,4.78,2.0,0.8,,,,,,,,,,,3 7.71,1920,4.61,2.0,0.8,,,,,,,,,,,38.00,1880,4.50,2 .0,0.8,,,,,,,,,,,38.30,1880,4.61,2.0,0.8,,,,,,,,,, ,38.61,1880,4.75,2.0,0.8,,,,,,,,,,,38.91,1840,4.67 ,2.0,0.8,,,,,,,,,,,39.21,1840,4.42,2.0,0.8,,,,,,,, ,,,39.50,1840,4.50,2.0,0.8,,,,,,,,,,,39.81,1800,4. 31,2.0,0.8,,,,,,,,,,,40.11,1800,4.44,2.0,0.8,,,,,, ,,,,,40.41,1800,4.61,2.0,0.8,,,,,,,,,,,40.71,1760, 4.25,2.0,0.8,,,,,,,,,,,41.01,1720,4.39,2.0,1.5,,,, ,,,,,,,41.30,1680,4.33,2.0,1.5,,,,,,,,,,,41.61,164 0,4.14,1.6,1.5,,,,,,,,,,,41.91,1560,4.03,1.6,2.3,, ,,,,,,,,,42.21,1520,3.47,1.6,2.3,,,,,,,,,,,42.51,1 480,3.69,1.6,3.0,,,,,,,,,,,42.81,1400,3.58,1.6,3.8 ,,,,,,,,,,,43.11,1360,3.42,1.2,3.8,,,,,,,,,,,43.41 ,1320,3.22,1.2,4.5,,,,,,,,,,,43.71,1240,3.31,1.2,4 .5,,,,,,,,,,,44.01,1160,2.83,1.2,0.0,,,,,,,,,,,44. 31,1160,3.03,1.2,6.0,,,,,,,,,,,44.61,1080,3.06,1.2 ,9.0,,,,,,,,,,,44.91,1000,2.97,1.2,11.3,,,,,,,,,,, 45.21,960,3.00,1.2,8.3,,,,,,,,,,,45.51,800,3.11,1. 6,21.8,,,,,,,,,,,45.81,680,8.39,4.3,19.5,,,,,,,,,, ,46.11,760,2.78,1.2,3.0,,,,,,,,,,,46.41,760,4.39,2 .4,19.5,,,,,,,,,,,46.71,760,4.50,2.0,7.5,,,,,,,,,, ,47.01,760,4.61,2.0,7.5,,,,,,,,,,,47.30,760,4.33,2 .0,8.3,,,,,,,,,,,47.61,760,4.28,2.0,10.5,,,,,,,,,, ,47.90,800,4.53,2.0,6.8,,,,,,,,,,,48.21,800,4.44,2 .0,3.8,,,,,,,,,,,48.51,800,4.03,2.0,3.8,,,,,,,,,,, 48.80,800,4.06,2.0,6.8,,,,,,,,,,,49.11,800,3.92,2. 0,9.0,,,,,,,,,,,49.41,760,3.94,2.0,12.0,,,,,,,,,,, 49.71,760,4.06,2.0,14.3,,,,,,,,,,,50.01,760,4.64,2 .0,14.3,,,,,,,,,,,50.30,760,4.33,2.4,19.5,,,,,,,,, ,,50.60,760,4.69,2.4,9.8,,,,,,,,,,,50.89,800,4.25, 2.4,6.0,,,,,,,,,,,51.21,800,4.28,2.4,6.0,,,,,,,,,, ,51.50,800,4.47,2.0,6.8,,,,,,,,,,,51.80,760,4.44,2 .0,6.8,,,,,,,,,,,52.10,720,2.17,1.6,19.5,,,,,,,,,, ,52.41,720,5.81,2.4,6.8,,,,,,,,,,,52.69,760,3.69,1 .6,1.5,,,,,,,,,,,53.01,760,4.36,2.0,10.5,,,,,,,,,, ,53.30,760,4.47,2.0,8.3,,,,,,,,,,,53.61,800,4.25,2 .0,6.0,,,,,,,,,,,53.91,800,4.33,2.0,6.0,,,,,,,,,,, 54.21,800,4.33,2.0,5.3,,,,,,,,,,,54.50,800,4.33,2. 0,6.8,,,,,,,,,,,54.79,760,4.17,2.0,9.8,,,,,,,,,,,5 5.10,760,4.03,2.0,11.3,,,,,,,,,,,55.40,760,4.03,2. 0,11.3,,,,,,,,,,,55.70,760,4.11,2.0,11.3,,,,,,,,,, ,56.00,760,4.36,2.0,9.0,,,,,,,,,,,56.30,760,4.39,2 .0,7.5,,,,,,,,,,,56.60,760,4.28,2.0,6.8,,,,,,,,,,, 56.90,760,4.03,2.0,8.3,,,,,,,,,,,57.21,760,4.19,2. 0,13.5,,,,,,,,,,,57.50,760,4.31,2.0,11.3,,,,,,,,,, ,57.80,800,4.31,2.0,9.0,,,,,,,,,,,58.11,760,4.36,2 .0,9.0,,,,,,,,,,,58.40,800,4.28,2.0,7.5,,,,,,,,,,, 58.70,760,4.19,2.0,7.5,,,,,,,,,,,59.00,760,4.22,2. 0,9.0,,,,,,,,,,,59.30,800,4.31,2.0,7.5,,,,,,,,,,,5 9.60,760,4.25,2.0,8.3,,,,,,,,,,,59.90,760,4.28,2.0 ,7.5,,,,,,,,,,,60.20,760,4.11,2.0,8.3,,,,,,,,,,,60 .49,800,4.22,2.0,6.8,,,,,,,,,,
I replaced the coolant temp sensor, deleted all fault codes. Then I went for a ride to check if the fault codes will come back and unfortunately they came back. I used break cleaner to find any vacuum/boost leaks, but I did not find any.
I did a boost reading with VCDS. Here are the results. Is it normal or not?
Sten M
05-19-2018 11:46 AM
Sten M
11-09-2017 09:21 AM
EasTTcoasTT
01-12-2004 09:51 AM
Black Sunshine
08-12-2003 05:17 PM
