Problems aligning xenon ecodes with VAG-COM
I just installed my second pair of ecodes after my accident and I was trying to realign my lights, but it keeps on giving me errors when I try to get vag to "learn" the new settings in groups 001 and 002.
Here is what I got after I scanned it:
Address 55 ---------------------------------
Controller: 4Z7 907 357
Component: dynamische LWR D07
Coding: 00060
Shop #: WSC 63351
3 Faults Found:
01539 - Headlights Not Adjusted
35-00 - -
01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
30-00 - Open or Short to B+
01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
I don't know if it means that the auto-levelers aren't installed correctly or what, but any advice would be awesome.
TIA!
Coding: 00060
Shop #: WSC 63351
3 Faults Found:
35-00 - -
TIA!
I just did this...the auto levelers HAVE to be in right and
must be 'zeroed' by running your VAG-COM on a level surface. Only then can you do the mechanical (under hood) adjustments. I didn't build my light assys. (bodyshop did) but I have to assume that the levelers have to installed correctly to be in the ballpark for your VAG to pass them.
Ross-Tech has all the how-to info. and they're on line on this site often and will help you.
Good luck!
Good luck!
Re: I just did this...the auto levelers HAVE to be in right and
<ul><li><a href="http://ross-tech.com/vag-com/cars/xenonalignment.html">http://ross-tech.com/vag-com/cars/xenonalignment.html</a</li></ul>
LINEa_roja_de_S
VAG-COM Discussion
03-17-2008 02:48 PM
shnoop234
08-17-2007 02:19 AM
tree580
01-29-2007 01:44 PM
mikelaory
06-30-2005 01:22 PM
HKsupastar
11-09-2003 04:55 AM
