SE: Audi a8 aux heating stop working Webasto
I wanther to start with cleaning the connector with conntact cleaner
Sunday,27,November,2022,15:59:01:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.1.0 (x64)
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: WAUZZZ4E6AN003333 License Plate:
Mileage: 266290km-165464mi Repair Order:
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 08 09 15 16 17 18 19 28 34 36 38 42 46 47 4F
52 53 55 56 5F 61 62 69 72 76
VIN: WAUZZZ4E6AN003333 Mileage: 266290km-165464miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 4E0 910 402 G HW: 4E0 907 401 D
Component: 3.0L V6TDI G000AG 0030
Revision: --H05--- Serial number: AUX3Z0I8369000
Coding: 0011773
Shop #: WSC 66565 257 00032
VCID: 2045BD42F3C3EA4FB9-8074
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4E1 910 156 Q HW: 09L 927 156 A
Component: AG6 09L 3,0 TDI RdW 0020
Revision: --H01--- Serial number: 4535016
Coding: 0000001
Shop #: WSC 02313 785 00200
VCID: 31634806A82953C726-8064
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 J HW: 4E0 614 517 CP
Component: ESP 5.7 allrad H50 0540
Coding: 0008357
Shop #: WSC 02313 000 00000
VCID: 2A515F6A85FF201FE7-807E
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 907 181 A
Component: FBS AUDID3 H12 0200
Revision: 02005112 Serial number: AUX3Z0I8369000
Coding: 0410624
VCID: 58B5D5A2EB13628F81-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00192 - Rear Left Door Handle Touch Sensor (G417)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 14
Reset counter: 132
Mileage: 264928 km
Time Indication: 0
Date: 2022.10.16
Time: 20:38:18
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
VCID: 244DB152E7DBF66FDD-8070
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 C HW: 4E0 820 043 K
Component: KLIMAAUTOMAT 017 0060
Revision: 00000037 Serial number: 00000000166801
Coding: 0002131
VCID: 1D3B84B6C4B1C7A792-8048
3 Faults Found:
00710 - Defroster Flap Positioning Motor (V107)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 9
Reset counter: 124
Mileage: 264773 km
Time Indication: 0
Date: 2022.10.04
Time: 15:43:48
Freeze Frame:
Voltage: 13.60 V
Temperature: 21.0°C
(no units): 84.0
(no units): 76.0
Temperature: 15.0°C
Raw, Form. N/A: 000 000 000
00065 - Rear Left Footwell Heater (Z42)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 38
Reset counter: 129
Mileage: 265121 km
Time Indication: 0
Date: 2022.10.24
Time: 16:45:21
Freeze Frame:
Voltage: 13.30 V
00066 - Rear Right Footwell Heater (Z43)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 120
Mileage: 266119 km
Time Indication: 0
Date: 2022.11.16
Time: 18:35:25
Freeze Frame:
Voltage: 13.80 V
Address 09: Cent. Elect. Labels: 4E0-910-279.clb
Part No SW: 4E0 910 279 S HW: 4E0 907 279 S
Component: ILM Fahrer H16 0240
Coding: 0133121
Shop #: WSC 02391 785 00200
VCID: 387575224B53828F61-806C
Subsystem 1 - Part No: 4E1 910 113 C
Component: Wischer WWS D3 H60 0420
Coding: 00000035
Shop #: WSC 02391
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00139548
Shop #: WSC 02391
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 E HW: 4E0 959 655 K
Component: Airbag 9.41 H01 4210
Revision: 91H01421 Serial number: 003CU000UMNY
Coding: 0430707
VCID: 2855A5629BF3120FF1-807C
Subsystem 1 - Serial number: 63328RB4050059557
Subsystem 2 - Serial number: 63428RB4050059266
Subsystem 3 - Serial number: 63528RB40500579CI
Subsystem 4 - Serial number: 63628RB4050059279
Subsystem 5 - Serial number: 63729RB4047F3F0F%
Subsystem 6 - Serial number: 63829RB4047F3EEA8
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 A HW: 4E0 953 549 C
Component: J0527 0530
Revision: 00H07000 Serial number: 90055092390021
Coding: 0012141
VCID: 2649AB5A91E7047FC3-8072
Component: E0221 H02 0030
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 901 G HW: 4E0 920 901 G
Component: KOMBIINSTR. VDO H86 0640
Revision: D06 Serial number: AUDID3I8101741
Coding: 0032123
Shop #: WSC 00010 123 00001
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0 265 081 AC
Component: Heizgeraet H08 0160
Revision: 0000000D Serial number: 00000009013887
Coding: 0000111
Shop #: WSC 00000 000 00000
VCID: 1A318FAAD59FB09F77-804E
5 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
004 - No Signal/Communication - Intermittent
00664 - Fuel gauge
002 - Lower Limit Exceeded - Intermittent
02072 - Control Module for Energy Management (J644)
01330 - Central Control Module for Central Convenience (J393)
00456 - Control Module for Access and Start Control (J518)
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0071
Revision: 00H06000 Serial number: 1200B099108076
Coding: F7F99F7F00028E00
VCID: 2D5B5476B411372702-8078
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 A HW: 4E0 919 158 F
Component: KLIMA-STG. FOND 017 0240
Revision: 00000022 Serial number: 00000000085869
Coding: 0000000
VCID: 2241B74AFDCFF85FAF-8076
Address 34: Level Control Labels: 4E0-910-553.clb
Part No SW: 4E0 910 553 L HW: 4E0 907 553 H
Component: LUFTFDR.-CDC H07 6340
Coding: 0015520
VCID: 2C5D59728F0B3E2F15-8078
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4063338
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H05 0090
Serial number: 00000924700001
Coding: 0003216
1 Fault Found:
01370 - Alarm triggered by Interior Monitoring
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 102
Mileage: 262136 km
Time Indication: 0
Date: 2022.11.05
Time: 22:38:00
Freeze Frame:
Bin. Bits: 00000000
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 F
Component: Türsteuer.FS BRM005 0180
Coding: 0028460
1 Fault Found:
02117 - Motor for Mirror Folding
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 122
Mileage: 264816 km
Time Indication: 0
Date: 2022.10.06
Time: 03:18:54
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 E HW: 4E0 907 289 E
Component: Komfortgeraet H11 0040
Revision: 00400011 Serial number: W040909230357
Coding: 0004712
VCID: 2B5F5A6E8A0539171C-807E
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P27H08 0090
Address 47: Sound System (J525) Labels: Redir Fail!
Part No SW: 4E0 035 223 N HW: 4E0 035 223 N
Component: BOSE G3 D3 H01 0100
Revision: AF001000 Serial number: 00000000001789
Coding: 0D000000
Shop #: WSC 02399 823 56573
VCID: 2649AB5A51E7047FC3-8072
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 D
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000124689
Coding: 0010101
VCID: 1E3983BAC9B7DCBF8B-804A
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 F
Component: Türsteuer.BF BRM005 0180
Coding: 0028460
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000221
Shop #: WSC 00010 000 00001
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0060
Revision: 00000001 Serial number:
Coding: 0000018
VCID: 69D3E0664079EB072E-803C
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 6
Reset counter: 130
Mileage: 264912 km
Time Indication: 0
Date: 2022.10.13
Time: 04:32:13
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4E0 035 053 K HW: 4E0 035 053
Component: Radio U Basic H45 0074
Revision: AB001007 Serial number: 331IR097513047
Coding: 010003010000000000
VCID: 244DB15227DBF66FDD-8070
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4E0 035 666 K HW: 4E0 035 666 B
Component: H-BN-EU H41 0187
Revision: -------- Serial number: 454F/097509970
Coding: 010100000000D7ED40002F0DFF7F00030001
VCID: 2E59537A79174C3F3B-807A
Subsystem 1 - Part No: 8R0 060 884 JN
Component: EUR 2022 3401
Subsystem 2 - Part No SW: 4E0 919 604 A HW: 4E0 919 604 A
Component: DU7 High Alu H43 0306
Serial number: 9357IL091003171
Subsystem 3 - Part No SW: 4E0 910 611 HW: 4E1 919 612 N
Component: E0380 Bedient H01 0050
Serial number: 00000000085294
Subsystem 4 - Part No: 8R0 906 961 A
Component: CD-Database 1293
2 Faults Found:
03276 - Please Check Software Version Management
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 11
Mileage: 264653 km
Time Indication: 0
Date: 2022.09.27
Time: 20:21:59
Freeze Frame:
Voltage: 12.10 V
03175 - Invalid Data Set
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 11
Mileage: 264653 km
Time Indication: 0
Date: 2022.09.27
Time: 20:21:56
Freeze Frame:
Voltage: 12.00 V
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000005757
Shop #: WSC 77976 146 85368
Subsystem 1 - Part No: 4E0 915 105 A
Component: von TU3 1111111111
Coding: 344530393135313035412054553331313131313131313131
5 Faults Found:
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 264653 km
Time Indication: 0
Date: 2022.09.27
Time: 20:37:13
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 264653 km
Time Indication: 0
Date: 2022.09.27
Time: 20:43:53
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 264653 km
Time Indication: 0
Date: 2022.09.27
Time: 20:44:03
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 264653 km
Time Indication: 0
Date: 2022.09.27
Time: 20:44:13
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 264653 km
Time Indication: 0
Date: 2022.09.27
Time: 20:44:23
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Türsteuer.HL BRM005 0180
Coding: 0028460
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 H HW: 4E0 907 383 G
Component: Anhaenger H08 0080
Revision: 2A002002 Serial number: 00000117156920
Coding: 0100000000000000
VCID: 2F674E7E7E1D453730-807A
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
Component: Türsteuer.HR BRM005 0180
Coding: 0028460
1 Fault Found:
02115 - Locking Unit for Central Locking
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 14
Reset counter: 131
Mileage: 264640 km
Time Indication: 0
Date: 2022.09.27
Time: 20:34:02
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 D HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0050
Revision: 00H12000 Serial number: 11020927200017
Coding: 0211008
Shop #: WSC 131071 1023 2097151
End-------------------------(Elapsed Time: 03:39)--------------------------
www.Ross-Tech.com
Coding: 0011773
Coding: 0000001
Coding: 0008357
Coding: 0410624
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 132
Mileage: 264928 km
Time Indication: 0
Date: 2022.10.16
Time: 20:38:18
Coding: 4063328
Coding: 0002131
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 124
Mileage: 264773 km
Time Indication: 0
Date: 2022.10.04
Time: 15:43:48
Freeze Frame:
Voltage: 13.60 V
Temperature: 21.0°C
(no units): 84.0
(no units): 76.0
Temperature: 15.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 38
Reset counter: 129
Mileage: 265121 km
Time Indication: 0
Date: 2022.10.24
Time: 16:45:21
Freeze Frame:
Voltage: 13.30 V
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 120
Mileage: 266119 km
Time Indication: 0
Date: 2022.11.16
Time: 18:35:25
Freeze Frame:
Voltage: 13.80 V
Coding: 0133121
Coding: 00000035
Shop #: WSC 02391
Coding: 00139548
Shop #: WSC 02391
Coding: 0430707
Coding: 0012141
Coding: 0032123
Coding: 0000111
5 Faults Found:
00664 - Fuel gauge
Coding: 0000000
Coding: 0015520
Coding: 4063338
Coding: 0003216
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 102
Mileage: 262136 km
Time Indication: 0
Date: 2022.11.05
Time: 22:38:00
Freeze Frame:
Bin. Bits: 00000000
Coding: 0028460
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 122
Mileage: 264816 km
Time Indication: 0
Date: 2022.10.06
Time: 03:18:54
Coding: 0004712
Coding: 0D000000
Coding: 0010101
Coding: 0028460
Revision: --H03---
Coding: 0000221
Coding: 0000018
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 130
Mileage: 264912 km
Time Indication: 0
Date: 2022.10.13
Time: 04:32:13
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 11
Mileage: 264653 km
Time Indication: 0
Date: 2022.09.27
Time: 20:21:59
Freeze Frame:
Voltage: 12.10 V
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 11
Mileage: 264653 km
Time Indication: 0
Date: 2022.09.27
Time: 20:21:56
Freeze Frame:
Voltage: 12.00 V
5 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 264653 km
Time Indication: 0
Date: 2022.09.27
Time: 20:37:13
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 264653 km
Time Indication: 0
Date: 2022.09.27
Time: 20:43:53
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 264653 km
Time Indication: 0
Date: 2022.09.27
Time: 20:44:03
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 264653 km
Time Indication: 0
Date: 2022.09.27
Time: 20:44:13
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 264653 km
Time Indication: 0
Date: 2022.09.27
Time: 20:44:23
Coding: 0028460
Coding: 0028460
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 14
Reset counter: 131
Mileage: 264640 km
Time Indication: 0
Date: 2022.09.27
Time: 20:34:02
Coding: 0211008
Rennered
04-18-2022 01:56 PM
johnd64
01-12-2017 09:02 PM
packge33
07-15-2012 12:17 PM
