Shareware Version. To Decode all DTCs
35-00 - Please Register/Activate
I received this fault code in two different controllers, does this mean I DEFINATELY have another DTC that it is not showing me or is it just a reminder that I want to register? Thank you.
Yes, you have faults that will be displayed once you register.
<ul><li><a href="http://www.ross-tech.com/vag-com/register.html">http://www.ross-tech.com/vag-com/register.html</a</li></ul>
Andy
Andy
Re: Yes, you have faults that will be displayed once you register.
Thanks for the info. I think I kinda screwed up. I cleared the codes. Is there anyway to figure out what they were? I copy and pasted the results to the text file. This is that file:
VAG-COM Version: Release 311.2-N
Control Module Part Number: 8D0 907 557 P
Component and/or Version: 1.8L R4/5VT MOTR HS D04
Software Coding: 06201
Work Shop Code: WSC 06335
2 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17968 - Shareware Version. To Decode all DTCs
P1560 - 35-10 - Please Register/Activate - Intermittent
Control Module Part Number: 8LO 862 257 B
Component and/or Version: CV-Pump, Alarm, RC D03
Software Coding: 16140
5 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Shareware Version. To Decode all DTCs
01372 - Shareware Version. To Decode all DTCs
01374 - Shareware Version. To Decode all DTCs
01370 - Shareware Version. To Decode all DTCs
So now that I cleared the codes is there any way to figure out what these are?
2 Faults Found:
5 Faults Found:
35-00 - -
StreetCrawler(Cole)
10-18-2004 02:19 PM
