VAG-COM Discussion
Throttle adaptation problem
Old Mar 2, 2006 | 04:17 AM
htm's Avatar
htm
New Member
Default Throttle adaptation problem
Hello,
need little help. Something wrong with my throttle can't do the alignment (adaptation).
Car Audi A4'95 1.6 ADP, VAG-COM v311.2
When first time entering Group 098 in [Measuring Blocks] adaptation status shows APD O.K., but when switching to [Basic settings] I get ERROR Group 098 Not Available.
When back to [Measuring Blocks] adaptation status shows ERROR.
The same situation I get with Audi-VW Tool.
Rotations are floating up and down when car is running on neutral gear.
What does this mean? Doing everything exactly like it is written in Ross-Tech website for TBA.
Thanks for help.
Old Mar 2, 2006 | 04:23 AM
Theresias's Avatar
All conditions met?
Old Mar 2, 2006 | 04:24 AM
Uwe@Ross-Tech.com's Avatar
Banned
What fault codes?
Old Mar 2, 2006 | 05:16 AM
Andy@Ross-Tech's Avatar
Banned
Does your engine have an Idle Stabilization Valve (ISV)?
Old Mar 2, 2006 | 06:15 AM
htm's Avatar
htm
New Member
Default Re: Does your engine have an Idle Stabilization Valve (ISV)?
if it's on airbox, coated with rubber, with rubber hoses attached and electrical connector, yes I have it.
Old Mar 2, 2006 | 06:23 AM
htm's Avatar
htm
New Member
Default Re: What fault codes?
no faul codes during the adaptation.
When engine is cold I sometimes get this fault:
16515 - Oxygen (Lambda) Sensor B1 S1: Signal too Low
P0131 - 35-00 - -
when engine running in normal operating temperature no this fault. what this could mean?
Old Mar 2, 2006 | 07:28 AM
Banned
Then you have no motorized throttle and hence no need/ability to do a TBA.
sadik007
Jun 5, 2006 06:38 AM
zszabo
Dec 31, 2004 12:19 PM
DonS4
11
Nov 26, 2001 03:42 PM
S4TNT
10
Sep 21, 2001 06:19 PM
