vag com issue (maybe)
I bought a ross tech vag com interface a bout a week ago but now I have some issues
The reasons I bought it were that I updated my MMI to 5570 and wanted to turn on my battery meter and instrument cluster settings. I also had the MIL on for maybe an year, but never went to the dealer, because most of the time MIL was off. Also, the airbag light came on after hitting a very big pot hole (a lot of here in Bulgaria :@).
So I changed the setings for the battery meter and instrument cluster, cleared the fault code for the airbag and I found out what was wrong with the engine - there was only one error in the engine. BUT I encountered the following issues:
When performing a test in module 03, until vcds is connecting with the ABS controller, all lamps that have to do with the braking system (abs yellow, big red on the display, handbrake red) started to blink and I hear the beep sound. When I close the controller, they go back to normal. Abs works perfect, car runs perfect, no lamps on at the dash. The other problem is that now vcds shows malfunctions on almost all modules. I dont know if it's necessary information, but I disconnected the battery for about 15 minutes. Now there is some error with some Turbocharger controller and ABS defective, which appeared after all the scans and the battery disconnecting.
When checking for errors all modules ONE BY ONE there are no errors. Only the engine and ABS ones. All these errors below are after performing AUTO SCAN. Could it be a vcds problem, rather than my car's?
Thanks in advance!!!
Here is the log:
Chassis Type: 4E0
Scan: 01 02 03 05 07 08 09 15 16 17 18 19 1E 25 34 37 38 42 46 47
4F 52 53 55 56 61 62 69 72 76 77
VIN: WAUZZZ4EX5N0113XX Mileage: 168210km/104520miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Cannot be reached 1100
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
69-Trailer -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E0 910 401 B HW: 4E0 907 401 B
Component: 3.0L V6TDI G000AG 0040
Revision: --H01--- Serial number: AUX3Z0DN153964
Coding: 0011773
Shop #: WSC 02313 785 00200
VCID: 1A37516B859F
4 Faults Found:
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 001 - Upper Limit Exceeded
Freeze Frame:
RPM: 756 /min
Torque: 35.1 Nm
Speed: 3.4 km/h
(no units): 11.0
Voltage: 13.91 V
(no units): 0.0
Temperature: 88.2°C
19804 - Control Circuit for Controller for Turbocharger 1 (J724): Electrical Malfunction
P3348 - 008 - Implausible Signal
Freeze Frame:
RPM: 756 /min
Torque: 35.1 Nm
Speed: 3.4 km/h
Duty Cycle: 1.0 %
Voltage: 13.91 V
Bin. Bits: 11001100
Absolute Pres.: 999.6 mbar
Absolute Pres.: 979.2 mbar
18279 - Transmission Mount Valve 2 (N263): Short to Plus
P1871 - 001 - Upper Limit Exceeded
Freeze Frame:
RPM: 777 /min
Torque: 31.2 Nm
Speed: 3.4 km/h
Voltage: 13.91 V
Bin. Bits: 0
Bin. Bits: 0
Bin. Bits: 0
Temperature: 88.2°C
29698 - Please Check Fault Codes in Comfort System Control Module (J393)
U1002 - 001 - Upper Limit Exceeded
Freeze Frame:
RPM: 756 /min
Torque: 31.2 Nm
Speed: 3.4 km/h
Duty Cycle: 1.0 %
Voltage: 13.91 V
Bin. Bits: 11001100
Torque: 230.1 Nm
Temperature: 88.2°C
Readiness: 0 0 1 1 1
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4E0 910 156 F HW: 09L 927 156
Component: AG6 09L 3.0lTDI RdW 0070
Revision: --H01--- Serial number: 0067551
Coding: 0000001
VCID: 254D7297BCE1
1 Fault Found:
18259 - Powertrain Data Bus: Missing Message from ABS Controller
P1851 - 000 - -
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 168211 km
Time Indication: 0
Date: 2004.03.25
Time: 00:47:23
Freeze Frame:
RPM: 768 /min
RPM: 768 /min
RPM: 0 /min
(no units): 30.0
(no units): 20.0
Temperature: 59.0°C
T.B. Angle: 0.0°
Address 03: ABS Brakes
Cannot be reached
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131
Component: FBS AUDID3 H04 0140
Revision: 01404004 Serial number: AUX3Z0DN153964
Coding: 0263168
Shop #: WSC 02311 785 00200
VCID: D8B38B633B13
Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
01316 - ABS Control Module
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 0
Reset counter: 134
Mileage: 168208 km
Time Indication: 0
Date: 2004.03.25
Time: 00:47:24
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 769 P HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 343JV047541387
Coding: 0000001
VCID: 3975AEE72059
Part No: 4E0 910 609 C
Component: Bedienteil MMI H42 0100
1 Fault Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 134
Mileage: 168211 km
Time Indication: 0
Date: 2004.03.25
Time: 00:47:23
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 A HW: 4E0 820 043 A
Component: KLIMAAUTOMAT 016 0340
Revision: 00000029 Serial number: 00000000056601
Coding: 1050689
VCID: 1B39546F8AA5
No fault code found.
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 K HW: 4E0 907 279 K
Component: ILM Fahrer H12 0210
Coding: 0020001
VCID: 306393C3F323
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000037
Shop #: WSC 02313
3 Faults Found:
00466 - Control Module for Steering Column Electronics (J527)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 174
Mileage: 168211 km
Time Indication: 0
Date: 2004.03.25
Time: 00:23:46
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 174
Mileage: 168211 km
Time Indication: 0
Date: 2004.03.25
Time: 00:23:46
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 174
Mileage: 168211 km
Time Indication: 0
Date: 2004.03.25
Time: 00:23:46
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655 G
Component: Airbag 8.4E+ H10 0940
Coding: 0430707
VCID: E3C9AC8F7255
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksдulenmodul H13 0040
Coding: 0002041
VCID: E5CDB2977C61
Component: Lenkradmodul H04 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 K HW: 4E0 920 900 K
Component: KOMBIINSTR. VDO H49 0200
Revision: D03 Serial number: AUDID3DN002851
Coding: 0000013
Shop #: WSC 00012 000 00000
VCID: 2751789FC6ED
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0 815 069 E
Component: Heizgeraet H07 0100
Revision: 0000000B Serial number: 00000009006406
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 1A37516B859F
2 Faults Found:
00456 - Control Module for Access and Start Control (J518)
02072 - Control Module for Energy Management (J644)
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 HW: 4E0 907 468 A
Component: Gateway H07 0070
Revision: 07 Serial number: 1600304824155C
Coding: FDFE7BC62B3104
VCID: E5CDB2977C61
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 134
Mileage: 168211 km
Time Indication: 0
Date: 2004.03.25
Time: 00:47:24
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBD6032237
VCID: 1C3B57738FAB
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0263168
VCID: D8B38B633B13
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 134
Mileage: 168208 km
Time Indication: 0
Date: 2004.03.25
Time: 00:47:24
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015520
VCID: 28537BA3CBF3
1 Fault Found:
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 134
Mileage: 168211 km
Time Indication: 0
Date: 2004.03.25
Time: 00:47:24
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 C
Component: MNS ECE H43 1060
Revision: 00000000 Serial number: 353K+047588609
VCID: 3B79B4EF2A65
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 134
Mileage: 168211 km
Time Indication: 0
Date: 2004.03.25
Time: 00:47:28
Freeze Frame:
Bin. Bits: 1100
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H02 0090
Serial number: 00000425800111
Coding: 0003092
VCID: 1D3D5A7794B1
Address 42: Door Elect, Driver Labels: None
Part No SW: 4E1 910 802 A HW: 4E1 959 801 C
Component: Tьrsteuer.FSmBRM001 0110
Coding: 0002336
VCID: 1F41607F9EBD
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040411090150
Coding: 0000584
VCID: 2751789FC6ED
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 134
Mileage: 168201 km
Time Indication: 0
Date: 2004.03.25
Time: 01:12:23
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 L HW: 4E0 035 223 C
Component: Amp.-Basis H42 0290
Revision: 00000000 Serial number: 00000047541399
Coding: 0000002
VCID: 264F759BC1E7
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 134
Mileage: 168211 km
Time Indication: 0
Date: 2004.03.25
Time: 00:47:24
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000051351
Coding: 0010101
VCID: 1E3F5D7B99B7
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 134
Mileage: 168208 km
Time Indication: 0
Date: 2004.03.25
Time: 00:47:00
Address 52: Door Elect, Pass. Labels: None
Part No SW: 4E1 910 802 A HW: 4E1 959 802 C
Component: Tьrsteuer.BFmBRM001 0110
Coding: 0002336
VCID: 1F41607F9EBD
2 Faults Found:
01331 - Door Control Module; Driver Side (J386)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 174
Mileage: 168208 km
Time Indication: 0
Date: 2004.03.25
Time: 00:23:38
01333 - Door Control Module; Rear Left (J388)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 174
Mileage: 168208 km
Time Indication: 0
Date: 2004.03.25
Time: 00:23:38
Address 53: Parking Brake Labels: 4E0-910-801.lbl
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000221
Shop #: WSC 00150 470 88389
VCID: 1D3D5A7794B1
3 Faults Found:
02596 - Rear Brake Pads Worn
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 168192 km
Time Indication: 0
Freeze Frame:
Voltage: 11.59 V
Count: 61
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 134
Mileage: 168200 km
Time Indication: 0
Date: 2004.03.25
Time: 01:12:23
Freeze Frame:
Voltage: 13.04 V
Count: 242
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 6
Fault Frequency: 19
Reset counter: 131
Mileage: 168192 km
Time Indication: 0
Date: 2004.03.25
Time: 00:24:59
Freeze Frame:
Voltage: 12.84 V
Count: 60
Address 55: Xenon Range Labels: None
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Revision: 00000001 Serial number:
Coding: 0000002
VCID: E2C7A98B6D4F
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 134
Mileage: 168216 km
Time Indication: 0
Date: 2004.03.25
Time: 00:48:17
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 B
Component: TUNER EU/US/RDW H41 0630
Revision: 00000000 Serial number: 304KV047604569
Coding: 0000001
VCID: 316596C7F829
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H11 0510
Revision: 00000000 Serial number: 00000000012985
Shop #: WSC 48364 141 57372
VCID: 20436383A3C3
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 1411080066
Coding: 344530393135313035412056413031343131303830303636
Shop #: WSC 00000 128 00289
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Tьrsteuer.HL BRM002 0060
Coding: 0002336
VCID: 1E3F5D7B99B7
1 Fault Found:
01336 - Data Bus for Comfort System
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 174
Mileage: 168208 km
Time Indication: 0
Date: 2004.03.25
Time: 00:23:28
Address 69: Trailer Labels: 4E0-910-383.lbl
Part No SW: 4E0 910 383 B HW: 4E0 907 383 B
Component: ANHAENGERELEKTR 003 0040
Coding: 0000001
VCID: 23496C8FB2D5
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 174
Mileage: 168208 km
Time Indication: 0
Date: 2004.03.25
Time: 00:23:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 134
Mileage: 168200 km
Time Indication: 0
Date: 2004.03.25
Time: 01:12:00
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Tьrsteuer.HR BRM002 0060
Coding: 0002336
VCID: 1E3F5D7B99B7
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 174
Mileage: 168208 km
Time Indication: 0
Date: 2004.03.25
Time: 00:23:38
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 174
Mileage: 168208 km
Time Indication: 0
Date: 2004.03.25
Time: 00:23:38
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: --.--.-- Serial number: 08720429300460
Coding: 0011008
VCID: 21456687A8C9
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 134
Mileage: 168211 km
Time Indication: 0
Date: 2004.03.25
Time: 00:47:24
Address 77: Telephone Labels: 4E0-910-333.lbl
Part No SW: 4E0 910 333 F HW: 4E0 862 333 C
Component: TELEFONMODUL EU 0770
Revision: 00000006 Serial number: T2AUDX0504HFWH
Coding: 0000004
VCID: 2247698BADCF
End ---------------------------------------------------------------------
http://www.ross-tech.com/vcds/downlo...a/current.html
