Vag com login problem...
I got a Vag of version 704.1 and wanted to do some setting to my 02 A4. How or what should I input for the login procedure in order to do the settings...? Thanks for your input.
Audiworld Premium Sponsor
This is not a VAG-COM problem, it's a procedural problem
and we need more information to help you. What are you attempting to do? Have you gone to the Ross-Tech A4 page? Try the link below.<ul><li><a href="http://www.ross-tech.com/vag-com/cars/audiB6.html">http://www.ross-tech.com/vag-com/cars/audiB6.html</a</li></ul>
-Bruce-
Ross-Tech, LLC
-Bruce-
Ross-Tech, LLC
Re: This is not a VAG-COM problem, it's a procedural problem
I intended to do some setting with the A/C system as well as the central lock. Is it possible to alter the min temp of the A/C other than LOW and I also wanted the central lock lock all 4 doors while driving automatically...Thanks for your help.
Did you read the page I linked? The locking at speed is certainly
addressed there.
As to the A/C, I do not think you can modify the low temperature. When you set it to low, it basically runs the compressor non-stop to deliver the coldest possible temperature. I do not think there is anything else you can modify. Perhaps others know better than I do.
-Bruce-
Ross-Tech, LLC
-Bruce-
Ross-Tech, LLC
Re: Did you read the page I linked? The locking at speed is certainly
I did read your link and should say thank a lot. But I just don't know how to LOGIN to do the settings. Any idea of get the LOGIN code for the job??
Please read my reply to your similar request here...
<ul><li><a href="https://forums.audiworld.com/vag/msgs/15200.phtml">https://forums.audiworld.com/vag/msgs/15200.phtml</a</li></ul>
Are Vag tool request no longer allowed, I think I got baleeted. Last request for anyone in bergen co
nemesisa6
NY / NJ / CT Discussion
08-19-2005 04:21 PM
aforeign
05-30-2003 08:28 PM
Grav
06-14-2002 09:22 AM
