225/45 or 235/45 on 17 x 7.5 for B5 A4?
I just picked up some barely used Audi B7-style split-fork 5 spokes, 17 x 7.5, ET 45 mm.
If I look at the Audi website, they come from the factory with 235/45 tires, although that is for mounting on a B7 A4.
I plan to mount these on my B5 A4. Would I be better off with a 225/45 or a 235/45 tire?
I was thinking that a 235/45 is a bit of an odd size for a B5 A4...
Thanks,
DD
Thanks,
DD
I'd go w/ the 235/45. The extra sidewall height will protect the wheel...
plus you get a slightly wider tire, too. As for tire brands, I recommend the one in my sig (my car or wifey's car).
AudiWorld Expert
There is a slight chance of rubbing with 235/45/17 and ET45 on a B5...
but most likely you'd be OK. Personally, I'd go with 225/45 because I don't see much advantage to running wider, especially on a stock car.
