Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Do I need to replace TPMS sensors when replacing worn tires?
Old Aug 17, 2009 | 07:53 AM
BMWBig6's Avatar
Default Do I need to replace TPMS sensors when replacing worn tires?
I am surprised this hasn't come up before (or maybe it has and I didn't find it when searching the archives). I found a couple archived threads that mentioned the TPMS batteries may only last around 5 years. Does that mean I should order new TPMS sensors when I order replacement tires for my TT? The car is less than 2 years old, and has about 22,000 miles on its original tires.
Can the batteries in the sensors just be exchanged for fresh ones (if they are even sold separately)?
Old Aug 17, 2009 | 10:11 AM
AnthraciteCoupeGT's Avatar
The batteries are non servicable, I wouldn't replace the TPMS until they wear out personally unless you've got money to burn.
Old Aug 18, 2009 | 05:24 AM
BMWBig6's Avatar
Sounds reasonable enough. But can the sensors be replaced with the tires mounted? Or if the batteries die before the new tires are worn, will I have to pay the expense of dismounting, remounting, and re-balancing the tires just to service the TPMS? (Pardon my ignorance if the TPMS valve stems can just be swapped out externally without removing the tires.)
Old Aug 18, 2009 | 11:39 AM
Alkivar's Avatar
Audiworld Member
the TPMS sensor is mounted inside against the rim underneath the tire, to replace you would need to unmount and remount the tire.
Old Aug 18, 2009 | 11:50 AM
Gary@Tirerack.com's Avatar
Former Vendor
Even so, I still wouldn't pre emptively replace them. You may need another set of tires before that time, or the batteries may last well beyond their rated time.
Old Aug 18, 2009 | 02:03 PM
BMWBig6's Avatar
OK, thanks for all of the replies and advice. Is 5 years truly the typical battery life for these things? Why couldn't they make them kinetically recharge like some wristwatches.
Old Aug 18, 2009 | 03:17 PM
Alkivar's Avatar
Audiworld Member
kinetic charging watches are actually quite fragile, you wouldnt be able to make it rugged enough to survive the abuse of being bolted to the wheel and still get enough of a charge out of it
akingzkid
15
Jul 14, 2018 03:22 AM
dreamcar2012
A4 (B8 Platform) Discussion
Feb 22, 2015 07:52 PM
jimboL
Q7 MK 1 Discussion
Dec 3, 2007 05:51 AM
CMSF
Nov 27, 2001 08:11 AM
SwifTT
Mar 7, 2001 12:11 PM
