I, along with Ron_C's help, put together a A4 Tire Calculator - check it out on my site
AudiWorld Expert
It'll suggest the closest profile for a given wheel diameter and tire width, as well as showing you how far off your speedo will be.
click the link below (or my sig pic) and then "Tire Calculator"<ul><li><a href="http://drive.to/marksa4">Mark P's Quattrobonium</a></li></ul>
AudiWorld Expert
com'on, you can figure that out...........
if you tried those tire combinations, you would see that one is 0% from ideal, so thus that must be the one I based it off of.
I did think this over a fair amount, and here's my thoughts:
The speedo is probably set for one tire size, regardless of what tires you get on your car (ie sport pkg).
The four tire options are:
1.8T stock (15's)
1.8T Sport (16's)
2.8 stock (16's)
2.8 Sport (16's)
so therefore, I went with the 16's.
1.8T stock (15's)
1.8T Sport (16's)
2.8 stock (16's)
2.8 Sport (16's)
Mark you need to make your calc be able to show a negative percentage
For example if you go from a 205/55/16 to a 235/40/17 the difference is -1.9%(in otherwords your gearing change based on wheel diameter makes acceleration increase and decreases top speed)
AudiWorld Expert
I intentionally took the absolute value
the speed section tells you if you are going faster or slower.
so, then it's just a matter of which is closest to the stock size, so I decided against +/-
However, I did think of putting it back, just to give the user a better visual feeling of where 0% would be.
andre d
05-09-2002 02:57 PM
GADGT
03-09-2001 04:06 PM
Mark P
02-19-2001 08:44 AM
