Offset Question - Allroad
Thanks
H&R's are high quality so I wouldn't expect you will have vibration or other mismatch issues.
DRA's bolt to your hub, so you use the STOCK lug bolts to in turn bolt to the spacer--one of the things that makes the DRA's a nice set up if you like stock bolt up. If I have the allroad offset right, I would guess you are looking at either the 25mm (per side) spacer to keep it at about stock offset, or 30mm to push it out more.
By the way, not sure which S4 you mean, but if you are talking about the old 2.7T S4, why not buy C5 S6 wheels (the same six spoke ones)? That gets you to a 35mm offset too.
http://classifieds.audiworld.com/sho...duct/32/cat/14
