Problem with tire ding?
<center><img src="http://pictureposter.audiworld.com/13113/tire_ding.jpg"></center><p>Looks like someone backed into a curb ... skinned the edge of the rim and pulled a flap on the side of the tire wall. Does this weaken the tire significantly? I'm worried because it's in the sidewall. Total thickness of the piece at its deepest is 3-4 mm.
Ditto on replacement. (m)
Like TedK said sidewalls cannot be repaired due to the high cornering stresses that they undergo. Given that same issue, since the sidewall is damaged you have compromised the integrity of the tire, alas, you should replace.
Call me if I can help with them!
jussnb
07-26-2001 01:34 PM
