Rubbing with aftermarket wheels....need help
Guest
Posts: n/a
Greetings all. About 2 months ago I installed a set of Neuspeed sport springs on my fwd 1.8T and also stepped up to 17x8 Borbet Type T's with 225/45/17 Sumitomo's. Everything went fine for about a month, and then started getting rubbing noises from the fronts. The noise has become more pronounced, particularly when coasting to a stop? Any idea what could be causing this? I'm running 35psi all around. Thanks in advance,
Raja
Raja
Guest
Posts: n/a
Need more info
Does it happen turning? Straight? all speeds? Constant all times?
Have you looked at the tires/wheels for wear or marks?
Possible issues are brakes also.
There were problems with some people and the bolts used to mount new wheels and the rotors.
Guest
Posts: n/a
Re: Need more info
Reggie, thanks for responding. The "rubbing" occurs both when turning and when going straight. Particularly when coming to a stop I can hear the distinct sound of something rubbing as the car coasts to a stop. I didn't hear anything much when I first installed the wheels and springs, at which time the wheels were at 32psi. As time wore on I started to hear some rubbing. Then I increased the tire pressure to 35psi (following advice from Gary@Ronal) and the rubbing definitely became more pronounced. Then I flew over a speed bump doing about 80mph one day (taking a friend to the hospital) and when the car landed I heard rubbing. I've tried to look under the wheel wells to see if I can see any marks on the tires, but haven't seen anything. Again, it sounds like just the front wheels, but I can't be sure. Thanks again for any advice you can give.
Raja
Raja
RS4TT
01-04-2005 02:44 PM
audinutt
13
02-23-2004 08:30 AM
