Scratched rim... will it rust? Stock 99.5 1.8T (non-sport) rim.
Guest
Posts: n/a
I'm worried because I live in the Chicago area (I recently moved here from Texas and haven't been through a winter yet... it's coming though!) I scratched the "lip" part, right next to the tire. It's a 3" long scrape, fairly deep. Damn me and my carelessness. I was trying to get close to the curb (to avoid dings! ironic isn't it, Alanis should put that one in her song). If I don't get it fixed, will it rust during the winter with the harsh environment, or will the fact that they are an aluminum alloy (I think) save them from that orangey (a word?) fate? Thanks,
Anthony
Anthony
Guest
Posts: n/a
Rubbish, Aluminium rusts faster than Steel.
Have you ever seen a clean piece of aluminium?
I think not, It rusts so fast that that within seconds of have a clean surface, it is coated with a film of aluminium oxide.
This Oxide is dense that it does not allow oxygen molecules to attack further aluminium.
Try this, get a sheet of Aluminium foil, use mercury, (Mercury is the solvent for alu oxide)
and with in seconds holes will appear, and if air is totally still you will get towers of oxide build.
Further point, If aluminium did not rust, It would be a naturally occuring mineral, But it is not, it is made from aluminium oxide which is its natural state.
Sorry for the Chem Lesson.
Guest
Posts: n/a
Don't feel too bad, I did the same thing (more)
That lip sticks out just enough to catch it on a curb. I'm planning on filing the area, then using a bit of fine sandpaper. A little Audi Light Silver (metallic) touch-up paint should do the trick, then hit it with a few coats of clear-coat - that should keep it from rusting I think.
HDClown
Auto Detailing Discussion
08-22-2004 07:23 AM
Arch57
02-24-2003 05:32 AM
rap413
11-26-2001 08:30 AM
