spare tire
spare tire
I'm installing 18" wheels and tires on my Audi A4 2.8 and was wondering if the stock spare tire will work with new wheels/tires if I get a flat? My stock wheels/tires are 16".
AudiWorld Expert
If the outside diameter of the tires is the same - then the answer is yes
you can check it at this link.
One other reminder - the wheel bolts with your new wheels may not fit the spare - so you need to carry a set of wheel bolts for use with the spare.<ul><li><a href="http://www.miata.net/garage/tirecalc.html">Tire size comparator</a></li></ul>
Re: spare tire
on a B5A4 if your spare is 205/55R16 and the new tire size is 225/40R18 this is no problem for usage as a spare. Both are right around 25"
Reggie makes a good point as well... be sure to carry a set of OE lug bolts in case the bolts for your new wheels are different.
Tapakegovagnaps
Mid Atlantic Discussion
15
03-22-2007 06:05 AM
