2.7T APB - misfires cyl 3
After engine swap (APB to used APB) and ICM delete (FSI coil conversion), plus new CM FX400 with single mass flywheel, I have consistent misfires on cyl 3. Idle, part throttle.
Only after warm up, there is a very small window where misfire counter stops and engine appears to run smooth: VERY little throttle (-3 to 0 on the boost gauge).
I am at the end of my wisdom after:
- verify spark
- verify fuel
- swapped coils, plugs, injectors
- replace plugs, injectors
- swapped MAF
- swapped MAP
- swapped FPR
- installed fuel pressure gauge
- swapped ECU
- verified firing order (video)
- injector output test
- compression test (all 6 have 170 psi)
- leak down test (cyl 1-3 under 6%)
- valve cover removed, cam chain timing good
- leak test (professional 'smoker')
- pressure test (through MAF to 10 psi on boost gauge)
- throttle body alignment VAGcom
- wire trace coil signal to ECU pins
- wire trace injector signal to ECU pins according to diagram below
- resoldered
- changed wiring to separate ground for coils directly to engine ground
- VAGcom cam timing verified (block 90-93).
- Noid light check of spark signal and injector signal.
Bought oscilloscope to take a closer look at spark signal, cam signal, crank/engine speed sensor signal, injector signal. Can some give tips/suggestions how to use osci for diagnostic?
Any suggestions, tips what might cause the misfires on cyl 3?
Could a lazy valve or lifter on cyl 3 cause the issues (despite good compression and leak down)?
Is it perceivable that the new Clutchmaster flywheel might cause the issue (bad/damaged/dirty tooth on the timing ring)?
Cam sensor? Crank sensor?
- verify spark
- verify fuel
- swapped MAF
- swapped MAP
- swapped FPR
- swapped ECU
- resoldered
ianlionzion
10-21-2007 09:57 PM
velo
12-18-2003 03:52 PM
