Q7 2007 4.2 head gasket failure
Old 07-19-2014, 10:37 PM
vaspc's Avatar
Default Q7 2007 4.2 head gasket failure
Just signed up . My first post to forum. Has any one ever had one fail or replaced them and if so can it be done in car or is it engine out. cheers
Old 07-20-2014, 09:41 PM
vaspc's Avatar
ps its a 4.2 tdi
Old 05-26-2019, 10:19 AM
Tronvi's Avatar
Hi, did you ever find out if you needed to take the engine out? What symptoms did you have to know it was a head gasket failure?
Thanks for reply
Old 07-29-2019, 10:15 AM
Chachboi's Avatar
I had bought a 2007 with a misfire and losing coolant without leaks problem. Turned out to be intermediate cooling o-rings found in the back of the engine, spark plug gap, bad coil, and a broken coil connector. It had 125k miles. Never heard of a head gasket failing. The o-ring is replaced when the head gasket is replaced so it is a less-known fact. also removing the oil cap and looking for places in the head where it looks like oil won't touch or even if it looks like coolant in the oil this may be a good check. Doing a compression test is the easiest way to tell or not. Any standard shop can do a compression test if needed.
Audi Kid
01-14-2019 02:56 PM
jc1113
06-23-2016 10:00 AM
ATH
01-03-2005 10:30 AM
Linux
Audi 100 / A6 (C4 Platform)
05-08-2002 10:32 AM
bkv
16
10-24-2001 03:28 PM
Quick Reply: Q7 2007 4.2 head gasket failure
