Cylinder 1 misfire code
Old 09-09-2012, 07:36 PM
skim464's Avatar
Default Cylinder 1 misfire code
Hello everyone
I own 1996 Audi A4 Quattro, 183,000 miles on it
Oil and coolant was flushed and changed 3000 miles ago due to pressure plate work job.
I have this misfire code for Cylinder 1 misfire. I do not think it misfires during trip but it noticeably misfire from time to time on start up. It may misfire for 3 seconds and idles just fine.
So far..
Compression Test Done -> All cylinders read 160~180 psi at around 160~180 F Temp, dry test
Spark Plug in cylinder 4 was swapped with one from cylinder 1 for testing purpose, in the mean while, plug from 4 was a bit worn, so i changed it with a new one, and the factory gap of 0.32 made it misfire like a CHAMP so I regapped all plugs to .40, feels much better now, but misfire still exist
I also performed intake seal test w/ carb cleaner, didnt notice any change in engine RPM or behavior during the test... so
I conclude that
Head Gasket, Intake Gasket, Injector Seal, Plugs, Valve Seal and Guide are in a good working order...(Unless you think so, please post)
What else could cause a misfire only on start up?
Old 09-10-2012, 02:49 AM
Tech Guru
4Driver4's Avatar
Injector?
Old 09-11-2012, 04:23 AM
skim464's Avatar
Could be leaky.. well at leasr it reads right ohm
Old 09-11-2012, 08:26 AM
Former Vendor
ALLDATAdiy INFO's Avatar
ALLDATAdiy will show you how to diagnose, repair the issue, and clear the code. Good Luck with your project!!
upops
04-07-2010 03:00 PM
miloradu
02-21-2010 10:52 PM
Fuzzbeaner
Audi 100 / A6 (C4 Platform)
06-18-2006 04:08 PM
Cheetie
06-02-2005 05:43 AM
CTMechE
10-20-2003 06:20 PM
Quick Reply: Cylinder 1 misfire code
