Anyone know how to put the car into Service Mode?
Old 07-23-2004, 09:48 AM
Chard's Avatar
Default Anyone know how to put the car into Service Mode?
I have to change my timing belt soon and wanted to put the car into service mode instead of taking the whole front end apart because I heard it's a whole lot easier. Is there a write-up out there that says how to do this? TIA.
Old 07-23-2004, 09:50 AM
Member
Silver Streakin''s Avatar
as difficult as it is to get a TB on, just pull the bumper cover and lock carrier, etc.
Old 07-23-2004, 10:13 AM
SilverA4Fun's Avatar
Default like Streak said, just pull the whoel bumper easier access to everything plus
you can make certain it is correct install and and all your nuts/bolts are torqued correctly the first time. And you have to still drain you wp to install it
Old 07-23-2004, 10:14 AM
Chard's Avatar
Default Sorry, never did any REAL engine work on my car
Aside from exhaust, I've never really had to work around my engine compartment. What's the lock carrier?
Old 07-23-2004, 10:50 AM
Head Cat Herder
Kris Hansen's Avatar
Default Service mode, aka service position IS taking the nose off...
Well, not all the way off. You remove the bumper, and 16 bolts or so, and slide the lock carrier forward on long metal rods that get threaded into one of the bolt holes for the bumper shocks. You don't even have to disconnet any of the radiator hoses.
Old 07-23-2004, 11:12 AM
Chard's Avatar
Default ohh, so I have to buy that metal rod?
So that I can slide the front end on it? Also, does anyone have a Bentley that shows the bolts I have to take off?
Old 07-23-2004, 11:17 AM
Head Cat Herder
Default No, you don't really have to..
What I do is use a stool or something to support the lock carrier at the bottom, and tie down straps to support it at the top.
Old 07-23-2004, 12:32 PM
Chard's Avatar
Default hmm, good idea. Anyone with a Bentlely?
Or would I easily be able to see which 16 screws I have to take out?
Old 07-23-2004, 12:40 PM
Head Cat Herder
It's in the tech article in the tech section of AudiWorld...
Old 07-23-2004, 01:35 PM
Chard's Avatar
Default didn't find the Bentley pic of the screws but
I was looking at got_root's EFK install directions and he's pretty clear about how to take off the AC condesor and the radiator. I guess it's not that much work after that, right? Or is it necessary to do this when you're putting it into service mode anyway? It doesn't seem TOO hard to get through those 2 steps at least.
mktbully
12-30-2008 07:33 AM
computrtutr
04-01-2008 09:16 AM
duburban
04-01-2008 06:04 AM
B5QShip | CFDQ
16
03-11-2007 08:35 AM
Jim De Arras
09-04-2000 10:18 AM
Quick Reply: Anyone know how to put the car into Service Mode?
