How to open the trunk from inside the car?
Old 01-22-2017, 09:59 AM
A1EK's Avatar
Default How to open the trunk from inside the car?
How do you open the trunk when you are inside the car? I normally have to remove the key and press the remote, but there must be an easier way?
Old 01-22-2017, 01:29 PM
W261w261's Avatar
At the rear of the driver's door map pocket are three pull switches. At least on my '03 there are 3 - I seem to recall the tilt alarm and inside motion sensor were deleted in '04. On mine at least, the bottom switch is for the trunk. If you pull it and the trunk doesn't unlock, it has been locked with the key at the trunk lock.
If by ​​​​​"inside the car" you mean "inside the trunk," there is a manual trunk release in there.
Do you have an owner's manual​​​? Might be worth getting one if not.
Old 01-23-2017, 12:16 AM
A1EK's Avatar
On my A4 Cab, the buttons on the door pocket are showing for sensors only, is this now for the trunk instead?
Old 01-23-2017, 03:33 AM
W261w261's Avatar
What year is your car? Is it a USA model?
Old 01-23-2017, 07:37 AM
W261w261's Avatar
I briefly looked into this, and apparently some Audi cab models do not have an interior trunk release. Perhaps yours is one of them.
Old 01-23-2017, 09:09 AM
lyleswk's Avatar
There also is the issue that you may not be able to put the seat down to get into the trunk which I used on my A4 a few times before I fixed the door switch. I know it's there to protect someone that locks themselves in the trunk...
Old 01-23-2017, 10:13 AM
A1EK's Avatar
I've recently bought the car and learning, its a B6 cabriolet, did you say that the rear seats fold down, I havn't tried that?
Old 01-24-2017, 05:25 AM
lyleswk's Avatar
They do on a sedan, but I have no idea on the cab. That part of the car is used to beef up the structure on most cabs and therefore may not have that ability.
Old 01-24-2017, 06:12 AM
snagitseven's Avatar
Hopefully, your car came with an operator manual. If so, there's a lot of good info in there.
GeoX750Li
15
03-18-2022 07:26 PM
WannaS6
A6 (C7 Platform) Discussion
26
05-29-2020 04:51 AM
Lain
TT (Mk3) Discussion
30
12-17-2016 02:42 AM
ooeddym
9
06-11-2016 07:29 PM
boxterduke
A4 (B8 Platform) Discussion
05-17-2015 05:02 PM
Quick Reply: How to open the trunk from inside the car?
