Trunk functionality
Old Jun 10, 2016 | 07:46 AM
ooeddym's Avatar
Default Trunk functionality
Is it normal that while the car is running you cannot open the trunk from the trunk handle or the key fob? I started the car this morning and walked around to open the trunk and the trunk handle was non responsive, only the trunk release on the driver’s door would open it.
Old Jun 10, 2016 | 09:15 AM
Shamoye Lewis's Avatar
Engineer
maybe the trunk is locked, did you unlock the door using the unlock switch first??
the inside button is override because you're already in the car ofcourse....
also if the trunk is locked valet style only the keyfob can open it....
Old Jun 10, 2016 | 09:26 AM
ooeddym's Avatar
I did unlock the car with the fob, then started it, got out of the car and walked to the back to open the trunk. I had the fob in my pocket while trying to open the trunk. When I realized the trunk wouldn't open from the trunk handle I tried using the open trunk button on the fob which also didn't open the trunk. After trying both of those I walked back up to the open drivers door and pushed the trunk button on the door which did work.
I shut the car off and closed the door, the fob was in my pocket, then I walked back to the trunk and the trunk handle opens the trunk as it should. Its almost like a security setting where the trunk can only be opened by the drivers door when the car is running. I wonder if it can be set by VCDS? My Q7 rear hatch can be opened while the car is running via the rear hatch handle.
Old Jun 10, 2016 | 11:12 AM
haggisuk's Avatar
It's normal behaviour, if the car is running you can only open from the drivers door pocket.
I would think that's to prevent thieves stealing stuff.
Old Jun 10, 2016 | 11:40 AM
ooeddym's Avatar
That makes sense, thank you for the response.
Old Jun 10, 2016 | 01:18 PM
richard-tx's Avatar
On my 2006 I can open the trunk while the engine is running. I just did it just to make sure.
Old Jun 10, 2016 | 01:40 PM
ooeddym's Avatar
That is very interesting, I don't remember seeing any specific trunk lock functionality in the MMI settings. I bet there is some setting buried in the VCDS that will change it. I just found this problem this morning before coming to work so I haven't had a chance to dig any deeper yet.
Old Jun 10, 2016 | 02:13 PM
storka's Avatar
If you look in your manual there are two settings from the trunk key lock position.
Just forget exactly what they do .
Old Jun 10, 2016 | 02:50 PM
ooeddym's Avatar
I will check that, thank you.
Old Jun 11, 2016 | 07:29 PM
Engineer
yea I can open mines also except if its in valet mode where the key it turn all the way the the right.....
ALEEXX
Apr 5, 2026 09:49 AM
dskny
11
Nov 12, 2021 10:47 PM
Ravill
Apr 27, 2016 10:43 AM
baron23
Audi A3 / S3 / RS 3 MKII
Apr 15, 2016 04:18 PM
Titua1915
NY / NJ / CT Discussion
Apr 15, 2016 06:29 AM
