Replacing Driveshaft with a used one
Old 11-16-2015, 06:26 PM
coffeysm's Avatar
Default Replacing Driveshaft with a used one
Hi everyone,
I'm pretty sure my center bearing is shot and I also had two different mechanics verify my conclusion. I ordered a used one from eBay for 100 bucks with 44K miles on it and the current car has almost 192K.
I read numerous posts about checking the run-out and making alignment marks on the drive shaft when rebuilding. However, how about when just swapping them out? Is it just a bolt up operation and making sure it's straight and true? I saw about colored dots, but what if the dots have faded?
Old 11-20-2015, 06:26 PM
Metronet's Avatar
You can use the attached PDF as a reference. It has detail instructions on installing the propeller/drive shaft.
When I put on a rebuilt one from Colorado Drive Shaft I tried my best to install it like the same one I removed. After carefully marking before removal and transfer the markings over to the rebuilt. I think as long as the driveshaft is dynamically balanced you should be fine.
Good luck. Cheers!
File Type: pdf
iNfiNkC
01-17-2009 08:46 AM
AudiSpeed84
9
05-07-2008 06:05 PM
AWD2KS4
12
02-03-2008 07:12 AM
quattros.org
11-23-2003 02:40 PM
craiglincoln
08-16-2003 10:17 PM
Quick Reply: Replacing Driveshaft with a used one
