any BTDTs for center support bearing?
Check the AudiFans archieves...There should be mention of using a BMW prop shaft bearing, and how to
change it.
I tried a search on AudiWorld and got zero helpful information just a couple weeks ago.
I'm just going to use the prop shaft from the '86 parts car until I can work on the existing prop shaft that is on the car.
Center bearing replacement
this is what's on the Blau web site. You may also find a replacement bearing on Ebay from time to time that requires some machining of the shaft. I bought a spare drive shaft on Ebay for $25 figuring its lots easier to swap drive shafts than doing the bearing when the time comes. Force5 will send you a used drive shaft for $100 or so<ul><li><a href="http://www.audiquattroparts.com/technical_tips/service%20bulletin/service_bulletin_center_support_.htm">http://www.audiquattroparts.com/technical_tips/service%20bulletin/service_bulletin_center_support_.htm</a</li></ul>
Reinman
05-31-2015 11:53 PM
shadowgates22
02-04-2011 10:56 PM
iNfiNkC
01-17-2009 08:46 AM
crotext
11-21-2002 08:44 AM
