A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
Oil leaks after a piston replacement
Old 09-30-2014, 06:38 AM
tempests4's Avatar
Default Oil leaks after a piston replacement
I went in to get my oil changed and the shop noticed leaks from the upper and lower pans as well as the oil pressure switch.
At 31K miles, I had the piston and piston rings replaced. I'm at 43K miles now, 18 months later and out of warranty.
Looking for thoughts and advice on how to approach this with the Audi deal and AoA. I'm being told this is a huge job to fix. Since my engine was basically rebuilt 13K miles ago I'm thinking I shouldn't be having these problems unless the repairs were substandard.
Thanks.
-Jay
Old 09-30-2014, 12:14 PM
FSures's Avatar
Have them check the PCV unit to ensure that you are not pressurizing the engine.
Old 10-01-2014, 11:16 AM
tempests4's Avatar
Any chance this would also explain a coolant leak? That's what I took it into my close shop to look at first. They couldn't find the leak and didn't notice the oil at first but I had to go back less than a week later because I got a low oil light. They found the filter was bad (the gasket was leaking oil) but after cleaning up the engine found that there were still leaks.
Coolant level seems stable. I did get a engine warning light and EPC light come on after starting the car (car wouldn't blow A/C, went away after turning car off/on again). Anyway, that's what made me get it into the dealer to deal with the issues ASAP as opposed to waiting to see if the coolant leak got worse.
tempests4 is offline Report Post
N'Syncro
33
02-16-2020 03:12 PM
Boosted01tt
1.8T Discussion
01-03-2017 05:55 PM
Optimusglen
09-02-2015 07:24 AM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
Quick Reply: Oil leaks after a piston replacement
