A4 Cabriolet (B6 Platform) Discussion Discussion forum for the B6 Audi A4 Cabriolet
Transmission Shutter
Old 11-23-2014, 10:39 AM
marxtoy's Avatar
Default Transmission Shutter
I have a 2003 audi a4 1.8T Cabrio that is a FWD with a CVT transmission. It has a problem of shaking or shuddering after take off while shifting between the lower gears. After spending thousands of dollars not getting the problem resolved by Audi garages and supposedly qualified mechanics, I am still not ready to give up on it as it only has 70K miles and is a cream puff. The problem only occurs while in automatic mode, not in standard mode so I am ruling out that the whole tranny needs to be replaced. I think it may be the TCM but no one (qualified mechanics who couldn't fix the problem) seems to agree with me. Any help would be appreciated. Thanks Mark
Old 11-24-2014, 08:54 PM
Mr. Chapps's Avatar
Any lights on? Codes? Abs malfunction can cause very similar shudder
Old 11-26-2014, 04:53 AM
marxtoy's Avatar
Hi
No lights, no error codes of any kind. usually if there is a TCM fault it will send a code, but none. it's only when its shifting gears in automatic mode. when it's in manual shift mode, no issues of any kind and the car drives fine.
Old 12-04-2014, 03:03 PM
ltooz_a6_a8_q7's Avatar
Default have you tried this adaptation procedure
Audi A8 used to have transmission and accelerator adaptation. I found this article, hope it works for you.
<a href="http://www.europeantransmissions.com/CVTAudiinstalliation.htm">CVT Audi Adaptation Procedure</a>.
Cheers,
Louis
Old 12-08-2014, 02:45 AM
marxtoy's Avatar
Louis
Thank you very much for the suggestion. I will forward it to my Audi mechanic and ask him to give it a try. I will let you know the results afterwards.
Mark
jpt150
02-09-2014 01:21 PM
Alpina_7
12-19-2012 10:27 AM
ssingh
02-10-2011 10:08 AM
GymzA4
04-23-2009 04:00 PM
mikeyspeed
06-24-2008 09:21 AM
Quick Reply: Transmission Shutter
