Help with timing belt
Hi, I'm new here. I've got a 1998 Audi A6 2.8L. 154000 miles on it... I was driving it in a 25mph zone and it quit running on me. Towed it home and took off the timing covers, the belt has partially slipped off on the passenger side and there are 4 teeth gone on the driver's side.
Do you think the valves ect are still okay? The motor still turns over with the starter, just won't fire. I'm hoping I can get by with replacing just the belt, tensioners, and pulleys.
Thanks for any help ahead of time.
Nice oil leaks. Be sure you do all the cam related seals too.
I bet you bent 6 exhaust valves on the side when the belt slipped...but you might get lucky. Stop cranking the engine over before create a problem on the other side. Us the timing belt tools to reset the timing when you do the job!
Before you waste any money on doing a timing belt service pull the plugs on the engine and scope the combustion chambers with an eye to bent valves. You may not wish to do the timing service if you have to pull the heads and replace valves or replace the motor.
is that the 30v engine ?
Seriously though, the OP should really think if it is worth the repair. Parts and Labor will be less than or around 1k (likely less) if you do a thorough job.
I'd do it on my Porsche in a second obviously and that is 35 or so years old, but my audi ? naw..
so it is fair for us to have owners consider it no ?
I'm with 4D4. Stop cranking it. Do a leak down test and see if it holds air. If it does, you may not have much of a problem and doing a timing belt job (which is about due anyway) will get your car going again.
If it leaks....you bent valves and then things get more intensive/expensive.
