rear windows switches /alarm related ??
hey guys .. I try to be brief.
just replaced drivers side door lock actuator . after replacement now the rear windows switch don't work unless I m holding down the master switch windows switch down . the main switch does work on all windows also the alarm no longer makes any sound also don't see any lights on the doors however I m still able to lock and unlock all doors with the control remote.. I don't have a vagcom cable to pull any codes . wondering if anybody can help me I m in Dallas plano area in TX
thank you
thank you
thank you
thank you
If it did not work before you did the job, you still have a problem.
yea I had no problems before except for the drivers side actuator . which I replaced
now , I have a v-checker scanner tried pulling whatever codes might be in there.
it read 1808.p1602 power supply B + terminal ......
checked my battery its kind of low on the voltage I m charging it right now. hopefully that might help...
ZPA117
A4 (B8 Platform) Discussion
09-08-2015 11:55 AM
stormchaser1967
09-02-2015 09:26 AM
stormchaser1967
09-02-2015 09:02 AM
