measuring blocks group 93 a6 c6 3.2 .... not right..???
hey all, saw these #'s and thought i could get some help....anyone seen this before and if so is it repairable?? thanks for any help offered... here goes.:
Measuring Blocks Group 93 Camshaft Adjustment (adaption values) -29.6*KW(Phase Position Intake Bank 1) 4.5*KW(PPIB 2) 2.3*KW(PP Exhaust Bank 1) 3.4*KW(PPEB 2)
MB Group 91 Camshaft Adjustment (bank 1 intake)
694/min Engine Speed(G28) 0.0%(Intake Camshaft Duty Cycle) 0.0*KW(adjustment specified) 7.9*KW(adjustment actual)
MB G 92 CA (Bank 2 intake)
709/min Engine speed (G28) 0.0%(Intake Camshaft Duty Cycle) 0.0*KW(adjustment specified) 0.4%KW(adjustment actual)
i can get more info if needed but thought i would start here..... i hope this isn't too far gone.....again any help here would be greatly appreciated!!
only negative(minus) # is at cam adjustment phase position intake bank 1
THANK YOU!
THANK YOU!
THANK YOU!
THANK YOU!
Actually you need to combine both the intake and exhaust bank values to determine how "off" you are. Ideally, you should be at 0, so if you intake read -4 and your exhaust read 4, then you would be at 0. Measuring block 93 will give you the phase values for the camshafts relative to the crankshaft. 0 would mean perfect synchronization
Did you have the engine running when you did these measurements? Those values are only calculated on engine start when the crankshaft syncs with the camshafts.
Engine running,
Hey, yes I did, I initially had a cps (g40) engine light p0340/0341, replaced both drivers side sensors, car ran smooth for about 5 minutes light came back on and starting running rougher, but not horrible..
measuring block 93....engine running...
hey raj99, i meant passengers side...rough day. its running a little rough but not shaking violently or anything...happy thanksgiving!!
Advanced measuring block
Hey, went into advanced measuring block engine running and checked voltage in all cylinders 2 (0.339), 6 (0.469) all others were well over 0.500. oodles great, rpm needle doesn't move at all.
hey, going to do a compression test, virgin run here..... any specific order on cylinders to test first? is there one fuse to pull or a couple (fuel)?? also, what results should i expect for an a6 c6 with 151k miles on her (150-170psi)???..... getting p0341 camshaft position sensor MIL thanks for any/all help!! greatly appreciated.
have you checked the solenoids? Your PM to me stated that your mpg is good. BTW, how is your battery? has it ever been changed and I'd get it tested properly or consider replacing it.
life4sk8
09-16-2013 03:56 PM
amirsafdari
11-19-2004 05:39 PM
nverfollow
09-12-2004 07:36 PM
blueT28EnYcEe
12-03-2000 10:25 AM
RiceBoy53
11-03-2000 09:06 PM
